Disc brakes that dont move wheels out - Chevelle Tech
 6Likes
  • 1 Post By Blackhawk
  • 2 Post By AZCamino
  • 2 Post By sz0k30
  • 1 Post By 64tempestwagon
post #1 of 10 (permalink) Old Jul 10th, 20, 8:37 PM Thread Starter
steve
Right now Im using 4 wheel drum brakes and a single master cylinder. Ive had many cars and this is a first. I have bought disc spindles (stock) and caliper brakets and calipers and rotors.... over 1 year ago!....now heres the reason for my delay.
I don't want to move out the front wheels . They sit perfect now and I want to keep the stance as it is.
I heard there are kits out there that DONT move the wheel out. Can someone tell me what parts I need to buy to start this off? Or is it better to get a complete kit?
I don't want to lose the 15" Rallys in front so please don't suggest C5 or LS1 FBody brake kits.
64tempestwagon is offline
post #2 of 10 (permalink) Old Jul 10th, 20, 8:46 PM
Re: Disc brakes that dont move wheels out
Good luck. I ended up with new wheels. 🤬
67
70 (SOLD)
Alwhite00 is online now
post #3 of 10 (permalink) Old Jul 10th, 20, 9:05 PM
Cody
Engineered Components, Inc. - Your One Stop Brake Shop!
EC-723ACK, 3/4 of the way down the page.
davewho1 likes this.
1971 Monte Carlo
Blackhawk is offline
post #4 of 10 (permalink) Old Jul 10th, 20, 11:27 PM
Bruce
Scarebird has an A body application that will allow you to use 14 inch drum brake wheels and actually brings the wheels in.
Scarebird GTOCF
78 Monte Carlo 1 piece 10.5 rotor/hubs
1990 Celebrity calipers
1979 Cadillac Seville hoses
hydro462 and davewho1 like this.
66 El Camino 396/325HP 4-Spd
My Build Thread:
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
66 Corvair My son's project. Small block, Powerglide, C5 differential and rear suspension
72 Chevelle wagon project
AZCamino is offline
post #5 of 10 (permalink) Old Jul 11th, 20, 8:26 AM
Roman
Originally Posted by 64tempestwagon View Post
I don't want to move out the front wheels . They sit perfect now and I want to keep the stance as it.
Moving the wheels outboard doesn't change the "Stance". Stance is how the vehicle looks from the side - how low or how high it sits. What changes is the track dimension.
Most disc brake kits move the wheels out 1/4 to 3/8 of an inch, something you will very likely never notice.
David Bates and davewho1 like this.
sz0k30 is offline
post #6 of 10 (permalink) Old Jul 12th, 20, 1:20 AM Thread Starter
steve
Thank you I heard about this but didn't know where to turn.
post #7 of 10 (permalink) Old Jul 12th, 20, 1:26 AM Thread Starter
steve
Actually Engineered Components have a kit that moves the wheels IN one inch. Now those old original Torque thrusts will fit/not stick out in front/scrape.
post #8 of 10 (permalink) Old Jul 12th, 20, 10:02 AM
Roman
No, but it sure as hell will cut into your turn radius. The inside of the tires will rub the frame every tight turn.
sz0k30 is offline
post #9 of 10 (permalink) Old Jul 12th, 20, 10:49 AM Thread Starter
steve
This is true but if youre running 235 60 15s on a car with 6 cylinder springs and a LS1 in it the front end is heavy enough to compress the front end down to where if you go into a driveway the tire might scape the fender lip. Putting the tire out another 1/2 inch WILL make a difference... not of stance but of track dimension. And definitely cause more scraping. The tire fits the fender really nicely now and I don't want to move it out. BTDT with another 64 Tempest in the 80s...
Also the straight Torque trust spoked originals from the 1960s (like a 15 x 7) stick out due to their positive offset so moving the hub in may actually be cancelled by the wheel positioned more out. Or am I completely wrong?
Kirk's67SS likes this.
post #10 of 10 (permalink) Old Jul 12th, 20, 2:19 PM
Bruce
I think you are correct, if your ARE Torque thrust offsets are similar to mine.
I have a 5 x14 stock Chevelle wheel with backspacing of 4 inches.
I have 2 each ARE Torque thrusts 6 x 14 "0" offset, with backspacing of 3 1/4.
I have 2 each ARE Torque thrusts 7 x14 1/2 " pos. offset, with backspacing of 3 1/4.
3/4 inch was gained with the ARE wheel switch. Moving the wheel in 1 inch (an extra 1/4 ") with the disc brake kit probably should only be a problem with the stock wheel or giant tires.
My Build Thread:
AZCamino is offline
