front spindles - Chevelle Tech
 3Likes
  • 1 Post By Ericnova72
  • 1 Post By jrkrace
post #1 of 15 (permalink) Old Jul 2nd, 20, 10:14 PM Thread Starter
front spindles
I have 1969 Chevelle with 396 - factory a/c - p/stg.*** I brought this car already restored *** so I do not know what was changed on front suspension *** issue is front of car sets too low *** I had frt. coils replaced and installed ball joint spacer s *** frt . is only 1 inch higher *** center top of wheel well set almost even with white letters *** question *** everybody sells drop spindles and stock ******* do anybody know if a company makes a spindle that is higher then stock ? Help !
cmaxx is offline
post #2 of 15 (permalink) Old Jul 3rd, 20, 3:00 PM
Harold
Re: front spindles
you likely have dropped spindles. Find another car to park next to, look under and compare parts......with permission of course
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #3 of 15 (permalink) Old Jul 3rd, 20, 5:27 PM
Cody
Re: front spindles
Which ball joints did you put a spacer on? Spacing the lower ball joint would lower the car. Ball joint spacers on the upper won't do anything for height, as the upper control arm doesn't do anything for height.
1971 Monte Carlo
Blackhawk is offline
post #4 of 15 (permalink) Old Jul 3rd, 20, 8:57 PM
Re: front spindles
Check to see if it has drop spindles on it . Easy to tell just be looking at the backside of the spindle, to see how high up from the bottom of the spindle forging/ball joint area that the bearing stub is pressed into the upright section
Stock spindle:
Drop spindle:
Notice the drop spindle has the axle stub 2" higher and has a second higher set of steering arm mount holes to preserve correct bump steer adjustment. also has that raised section above the top ball joint for the upper caliper mount bracket.
Are the lower control arms stock?? They make tubular arms with a lowering bottom spring mount section that will give you a drop even with stock spindles.
RAIDER SS likes this.
Ericnova72 is offline
post #5 of 15 (permalink) Old Jul 5th, 20, 12:16 PM
Re: front spindles
Take a wheel off, take a pic, and post it here.
What springs did you use? Small block springs will have your car sitting lower for sure.
'69 Malibu
Not2Fast is offline
post #6 of 15 (permalink) Old Jul 7th, 20, 12:37 PM Thread Starter
Re: front spindles
Thanks for the help **** spindles checked & are oem
cmaxx is offline
post #7 of 15 (permalink) Old Jul 7th, 20, 12:39 PM Thread Starter
Re: front spindles
thanks *** upper ball joint *** rtight it did not help
cmaxx is offline
post #8 of 15 (permalink) Old Jul 7th, 20, 12:40 PM Thread Starter
Re: front spindles
thanks **** spindles checked & they are oem
cmaxx is offline
post #9 of 15 (permalink) Old Jul 7th, 20, 12:41 PM Thread Starter
Re: front spindles
Thanks **** wheel off & spindles are oem
cmaxx is offline
post #10 of 15 (permalink) Old Jul 12th, 20, 12:32 AM
Re: front spindles
good luck ****
'69 Malibu
Not2Fast is offline
post #11 of 15 (permalink) Old Jul 12th, 20, 1:01 AM
Re: front spindles
What’s with ***?
BillyGman likes this.
72 SS 402/4 speed/Straub roller and a bunch of Duramaxes.....
jrkrace is online now
post #12 of 15 (permalink) Old Jul 12th, 20, 7:34 AM
Re: front spindles
Originally Posted by jrkrace View Post
What’s with ***?
Initially I thought he was swearing..... a lot
1967 SS 396 Chevelle
Formerly Bolero Red
Soon to be a 427 equipped Tahoe Turquoise head turner!
Kopfjaeger is online now
post #13 of 15 (permalink) Old Jul 12th, 20, 7:47 AM
Re: front spindles
What’s with ***?
*****LOL***** that's what I thought too***** what's with all the asterisks??????***************
BillyGman is offline
post #14 of 15 (permalink) Old Jul 12th, 20, 12:48 PM
Re: front spindles
Could be due to phone or I-pad app as a way to get space between sentences, I've seen some crazy looking hieroglyphics or Cyrillic looking stuff in posts from phones on other sites too.
post #15 of 15 (permalink) Old Jul 12th, 20, 9:50 PM
Re: front spindles
Oh, well then that would explain it
