1970 Chevelle rag joint compression - Chevelle Tech
 5Likes
  • 3 Post By 67ss4spd
  • 1 Post By Tom Mobley
  • 1 Post By LeoP
post #1 of 8 (permalink) Old Jul 2nd, 20, 4:40 PM Thread Starter
Okay...just mounted my new power gearbox and hooked up the rag joint. I noticed that one side of the rag joint compressed alot more than the other....could you guys take a look and tell me what I have done wrong here?
The bigger bolt, 9/16 is the one that compressed more, the smaller bolt 1/2 is the one that did not compress so much. Both are tight.
ID:	631840   Click image for larger version
s1nemesis1s is offline
post #2 of 8 (permalink) Old Jul 2nd, 20, 5:29 PM
Did you use shoulder bolts and put lock washers on the bolts thru the rubber? Or use nyloc nuts. You do not need to crank on them, the bolts on the rubber get 15-20ft lbs. and the pinch bolt (s) on the shaft gets about 25-30 ft lbs. did the rag joint have a ground strap?
67ss4spd is offline
post #3 of 8 (permalink) Old Jul 2nd, 20, 6:09 PM
Re: 1970 Chevelle rag joint compression
what's that thing sticking out of the top of the gearbox?
s1nemesis1s likes this.
Tom Mobley is online now
post #4 of 8 (permalink) Old Jul 2nd, 20, 6:14 PM
My Dorman 31011 rag joint did not have a ground wire but my original 1970 GM part certainly did.
So I made an all new ground strap to bridge across the rubber.
B52bombardier1 is offline
post #5 of 8 (permalink) Old Jul 2nd, 20, 6:39 PM
Is that a JEEP steering box?
Robinls5 is offline
post #6 of 8 (permalink) Old Jul 2nd, 20, 10:18 PM Thread Starter
Sounds like I need undo the bolts and retorque them correctly - I am sure they are cranked down pretty hard - Do you all think the damage is done? Should I just leave it alone?
Not sure about a ground strap, there was none.
Not sure what that is sticking up lol
And yes, it is a Jeep box
post #7 of 8 (permalink) Old Jul 2nd, 20, 10:40 PM
leo
You should really get the shoulder bolts and do it correctly, good luck!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #8 of 8 (permalink) Old Jul 2nd, 20, 11:13 PM Thread Starter
I am a bit confused - what shoulder bolts am I looking for? I appreciate the help!
