UMI control arms - Chevelle Tech
 6Likes
  • 1 Post By Rich66
  • 1 Post By Tom Mobley
  • 1 Post By Rich66
  • 1 Post By senna
post #1 of 15 (permalink) Old Jun 30th, 20, 7:43 PM Thread Starter
Rich
UMI control arms
Guys getting confused on this end, nothing new there...……...talked to a few UMI reps, not sure im getting this straight.
I have a 66 Gto, yeah, I know not a chevy thing, but a lot more info here on umi stuff...…...im looking at getting the upper & lower a arms, one tech recommended the 4056-2 upper and the 4031 lower.
Then another tech recommended the 4031 lower & the 4056 upper for good handling & comfort...………..then another tech recommended for Best handling with slightly less comport 4032 lower with the 4056...900 upper bj.
Not sure about the poly vs the Delrin stuff...……….so another option was the 403133-1 poly bushing kit.
Other option was the 403233-1 kit with the Delrin lower...……..
They thought the .09 bj was overkill for the way I drive...………...just wondering if anyone had this stuff on their car, or could steer me in the right direction.
Im just wanting the car to drive like a more modern car...……..hope that helps.
Any info would be great...…….im not doubing the techs advice, just want to hear from people running these numbers if possible...……….
Rich
Rich66 is offline
post #2 of 15 (permalink) Old Jun 30th, 20, 8:28 PM
Greg.
Re: UMI control arms
I bought these and installed them on my 67 Chevelle in 2013 # 403133
https://www.umiperformance.com/home/...front-arm-kit/
and love how they Ride/Handle on the Hwy or Street and Bends in the Road
even my Alignment Guy was happy about how easy they were to Shim them
At that time UMI Perf did not make the Adjustable Uppers
so if I were you I would get the Upper Adjustable # 4056-1 so no Shims needed for Alignment
and for Lower then get the # 4031
Or go hog wild with the # 403256-3 Kit
Ask / Talk to Ramey he provided me with great advise on what to buy with the way I use my car
[email protected]
And I am sure He/they will put the right kit together for you for a Kit Price
tell Ramey you were talking to Greg K. from Ottawa Canada
he has Pics of how my 67 car perfs with UMI Perf Parts
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 15 (permalink) Old Jun 30th, 20, 9:19 PM Thread Starter
Rich
Thank you Kirk...…….with those #"s you posted, they are similar to the 4056-2 upper & the 4031 lowers they recommended ……...so im taking it you have no preference between poly or Delrin bushings...………..looked into the 403256-3 kit...…….don't know if I want to shell out that kind of money for how I drive,. lol
I already bought the spc uppers last year # 94320...……….I have the 0.9 upper & lower 0.5 howe bj"s……….don't know why, just not sure this is the right way to go...……...don't like the idea of opening the frame holes to 1/2 inch, nbd, thought the umi stuff might be the better way to go here.
Rich
Kirk's67SS likes this.
Rich66 is offline
post #4 of 15 (permalink) Old Jun 30th, 20, 10:43 PM
I have the adjustable uppers and they still required some shims. I think they will only benefit you if you have other issues with the car (sagging frame, lowered, etc.). Mine had to be adjusted all the way in. The SPC adjustable units are actually superior for alignment - you should need no shims at all. The taller upper ball joint will help correct the bad factory camber curve.
I personally would not run polyurethane bushings. Either run rubber (don't think you can to that with the aftermarket control arms) or the Delrin (the adjustable uppers use a heim joint - or rod end bearing - , but my lowers have the Delrin).
My Chevelle w/ open headers:
1971-Chevelle is offline
post #5 of 15 (permalink) Old Jun 30th, 20, 11:09 PM
I've got an idea, why don't you quit calling them and asking the same stuff?
Alwhite00 likes this.
Tom Mobley is online now
post #6 of 15 (permalink) Old Jul 1st, 20, 3:09 PM Thread Starter
Rich
Now that is helpful advice, I call them to get some info on products, I get 2-3 different answers, I understand they are in the selling business so there gonna lean one way or the other...…...the reason I asked here is im assuming im getting some sound advice from people that are running these arms.
Maybe you could share your wisdom with me...……..and tell me "what I should ask them."
Rich
senna likes this.
Rich66 is offline
post #7 of 15 (permalink) Old Jul 1st, 20, 7:33 PM
Sorry, didn't mean to come across as a jerk. Well, from time to time I am a jerk.
anyway here's what I would get:
https://www.umiperformance.com/home/...lrin-bushings/ Their hardware kits call out 1/2" bolts so you may want to buy 7/16 bolts locally if you don't want to drill.
and
https://www.umiperformance.com/home/...r-ball-joints/ the tall ball joints fix the camber curve, the a-arms themselves correct the positioning of the upper ball joint so you can use a modern front end alignment with lots of caster. The chevelle/A-body front end was designed before radial tires come out.
Caveat: I haven't gotten used to the idea of the tall lower ball joints. That ball joint is the most heavily stressed piece on the car outside the engine. I just haven't ben able to get enthused about canti-levering the load on it. Others may differ, I'm ok with that.
Kopfjaeger likes this.
post #8 of 15 (permalink) Old Jul 1st, 20, 7:39 PM
Also, I would get the delrin stuff, it's good. Poly is softer and squeaks.
post #9 of 15 (permalink) Old Jul 2nd, 20, 10:51 AM Thread Starter
Rich
Hey Thanks Tom, sent you a pm before I seen your posts...…….gonna make sure I talk to Ramey just so I got this straight in my head.
Im thinking of going with this plan if it works.....I already have the spc uppers with the howe 0.9 bj……….then buying the UMI lowers and use the bj I already have now in their unit. Or just use the stock bj.
Don't really want to deal with SC&C anymore, I waited 4 months to get these arms last year, and that's without the virus going on, I got a better shot of dying before he sent me the lower arms. Even UMI said im waiting 4-5 weeks for their arms.
Would use my stock lowers, but with the 5.5 caster Mark suggests with his uppers, im thinking im running into tire rub issues with the stock lowers...…….not to mention when I get them off, who knows what shape there even in.
I'll get this straight yet. lol
Rich
Rich66 is offline
post #10 of 15 (permalink) Old Jul 2nd, 20, 11:29 AM
Bryan
I have the Stage 2 kit on my '66 shown here: https://www.umiperformance.com/home/...ering-stage-2/
If you order directly from them, they will let you add upgrades - I upgraded to the taller ball joints. I regret not upgrading to the adjustable upper arms as well, I would recommend this since it would make alignments a breeze.
Definitely a big improvement in the way it drives and I'm very happy with it!
'66 SS Clone
Fast Burn 385hp Crate 350 (for now)
Muncie M20 & 3.42 Posi
UMI Stage 2 Suspension all around
bry66 is offline
post #11 of 15 (permalink) Old Jul 2nd, 20, 11:59 AM
X2 even Poly body mounts squeak. I'd stay away from poly. She is a squeaking Ho
BillyGman is offline
post #12 of 15 (permalink) Old Jul 2nd, 20, 12:00 PM
Troy
Summit lists the SPC lower control arms with a ship date of 7/17.
I'm running the upper and lower SPC arms with the screw in Chrysler style Howe ball joints.
I understand not wanting to use SC&C, I had similar issues. But that doesn't discount the benefits or quality of the SPC parts.
Sent from my SM-T720 using Tapatalk
66 CHEVELLE
senna is offline
post #13 of 15 (permalink) Old Jul 2nd, 20, 12:07 PM
I put the power tour package on the 66 I have. It rides and drives very nice and handles like it's on rails.
BlueSS454 is offline
post #14 of 15 (permalink) Old Jul 2nd, 20, 4:40 PM
They really don't. You have to pull the side bolt completely out, tilt the control arm, adjust the heim joint in or out, then put it all back together. The SPC design is vastly superior for alignments.
post #15 of 15 (permalink) Old Jul 2nd, 20, 10:58 PM
Bryan
You know what? All this time I thought UMI had a similar design as the SPC arms but you’re right, I stand corrected!
'66 SS Clone
bry66 is offline
