1970 Chevelle Power Steering rag joint - Chevelle Tech
  • 1 Post By jahsun145
post #1 of 3 (permalink) Old Jun 30th, 20, 9:39 AM Thread Starter
Hello all,
I am getting ready to install a jeep box on my Chevelle - it has no power steering currently. Since I am replacing the gearbox, do I need to drop the steering column to replace the rag joint? If I do not have to that is nice. Let me know what you all think.
Thank you!
s1nemesis1s is offline
post #2 of 3 (permalink) Old Jun 30th, 20, 11:48 AM
Re: 1970 Chevelle Power Steering rag joint
Originally Posted by s1nemesis1s View Post
Hello all,
Thank you!
No when you drop the manual steering box swap the new one then. You will need to change lines/pump or use adapters for the lines, change the pitman arm as well since you are going to power. Make sure your pitman has the right diameter and spline count for the Jeep box
Billdini is offline
post #3 of 3 (permalink) Old Jun 30th, 20, 8:25 PM
Yup no need to do anything to the steering column. I removed my manual gearbox and rag joint all as one unit and installed the new power gearbox and rag joint all as one unit with no problems.
Sent from my SM-N950U using Tapatalk
s1nemesis1s likes this.
jahsun145 is offline
