Refurbish drumbrakes rear el camino 1971 - Chevelle Tech
 24Likes
post #1 of 37 (permalink) Old Jun 23rd, 20, 7:09 AM Thread Starter
if i want to rebuild my stock rear drum brakes. I want to renew everything except for the drum it self and the backing plate.
I find 2 or 3 hardware kits at summit. But dont know exactly which parts i need
Thnx in advance
Bart Fransen is offline
post #2 of 37 (permalink) Old Jun 23rd, 20, 7:50 AM
Re: Refurbish drumbrakes rear el camino 1971
Get new wheel cylinders while you are at it. I bought the kits but found that the original rear brake drum springs and other parts were superior to anything in a modern rebuild kit.
So I media blasted and repainted everything that was original and better and reused them. Same for my rear drums. Plenty of steel thickness remained. The hardest part of this job was getting the rusty drums removed. Second hardest part was remembering where each spring hooked onto and how to hook them.
Take LOTS of pictures after the drum comes off but BEFORE removing any brake parts.
Kirk's67SS and 427L88 like this.
B52bombardier1 is offline
post #3 of 37 (permalink) Old Jun 23rd, 20, 8:42 AM
NAPA. Wheel cylinders, brake shoes, rubber brake lines, & a hardware kit (includes all the springs & retainers).
LeoP, JJ'65 and Kirk's67SS like this.
69SS454 is offline
post #4 of 37 (permalink) Old Jun 23rd, 20, 11:58 AM
Do not change the brake adjuster rod with the one supplied in those kits, its usually the wrong length. I like to reuse the old springs if they are in good shape because as stated above are usually better than whats in those kits. And finally new wheel cylinders are cheap. Good quality brake shoes like Wagner or Raybestos work well.
Kirk's67SS likes this.
oldcutlass is offline
post #5 of 37 (permalink) Old Jun 23rd, 20, 12:55 PM
Here's a few photos from my 70
ID:	630930   Click image for larger version
ID:	630932   Click image for larger version
ID:	630934   Click image for larger version
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #6 of 37 (permalink) Old Jun 23rd, 20, 1:33 PM Thread Starter
I already took of the drums before so that will be easy.
So if i understand correctly, get new brake shoes and a wheel cilinder. I should not considering buying any new springs unless the current once are busted..
Other thing, why are people finding it hard or difficult to bleed and get air out of the brake system? Because that will be required when installing new brake cilinders
post #7 of 37 (permalink) Old Jun 23rd, 20, 1:52 PM Thread Starter
Why rubber brake lines? For 34dollar i get stainless steel lines for the rear axle.
B52bombardier1 likes this.
post #8 of 37 (permalink) Old Jun 23rd, 20, 2:12 PM
I would only replace the wheel cylinders if they are leaking. No need to mess with normally. If the rubber hose that connects the body brake line to the brake line on the differential is cracked, then I would replace that. Otherwise, just get shoes and a hardware kit. Have the drums machined at a competent shop, put everything back together, adjust the shoes, and away you go.
Kirk's67SS and 68-13427 like this.
My Chevelle w/ open headers:
1971-Chevelle is offline
post #9 of 37 (permalink) Old Jun 23rd, 20, 3:11 PM
Mr Bill
My local supplier (Carquest/Advance) show two different hardware kits depending on what size shoes you have . So you need to know that before you order hardware etc. Personally I would get it local so you can compare it to what you have now and exchange it easily if it isnt right.
Kirk's67SS, LeoP and 68-13427 like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #10 of 37 (permalink) Old Jun 23rd, 20, 3:34 PM Thread Starter
On summit i found the attached once.
Are these actually the lines running over the rear end or is this what you refer to "rubber hose that connects the body brake line to the brake line on the differential"
I couldnt find other brake lines at summit and for sure they arent rubber.
ID:	630952   Click image for larger version
post #11 of 37 (permalink) Old Jun 23rd, 20, 3:44 PM
This is the hose for my '71 (since we don't know what year yours is - you might update your information):
https://www.autozone.com/brakes-and-.../773747_0_1903
This hose connects the steel line that runs from the front of the car to the steel line that is on the differential housing. It has to be flexible, as it moves with the differential housing when the suspensions expands/compresses.
I highly doubt that you need to replace the steel line on the differential housing - the rubber hose is what usually goes bad (unless you live in the rust belt).
Kirk's67SS and LeoP like this.
post #12 of 37 (permalink) Old Jun 23rd, 20, 3:55 PM Thread Starter
I see, perfect.
Where can i update my car information? Sorry i am new around here
post #13 of 37 (permalink) Old Jun 23rd, 20, 4:08 PM
It's been so long since I have done it that I can't remember. Hopefully a site moderator will chime in with how to do it.
post #14 of 37 (permalink) Old Jun 23rd, 20, 10:25 PM
leo
Bart, at the top left corner of the page, click on usercp and take it from there!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #15 of 37 (permalink) Old Jun 23rd, 20, 11:05 PM
There is no reason to resurface the drums unless they are not true causing a vibration when you brake.
Kirk's67SS and JJ'65 like this.
