Installing Budnik wheel on stock column - Chevelle Tech
post #1 of 3 (permalink) Old May 22nd, 20, 10:08 PM Thread Starter
I have the OEM steering column in my '66. I have the Budnik Chicane steering wheel and a LeCarra Hub Adapter Kit (B-26422) that was recommended by Budnik for it. What I can't figure out is how to attach the horn button correctly.
Attached are a couple of photos (don't know why they both rotated when I added them here); one with all of the parts I have and one a little closer up. I still have the OEM turn signal canceling cam installed...I'm assuming I continue to use that? At about 10 oclock on that cam is a tube that comes forward, with a copper spring inside. Do I keep both of these? I'm assuming so, as to maintain contact with the other copper parts. And the spring that slips over the shaft...keep it?
Then I have that red wire with the spring attachment that came with the LeCarra
hub adapter...do I use this at all? I can see how the one end that has the spade terminal that will fit within the underside of the horn button. But I'm not sure where to place the other end? And the black ground wire on the horn button...not sure where to attach that either.*
And I'm not sure if I still use those OEM parts to the right; the aluminum disc with the plastic insert...?
If anyone here has installed a Budnik onto the stock column, I'd appreciate any info to help me.
ID:	627670   Click image for larger version
1966 Chevelle SS, 355 V-8, TH-350.
Gunn317 is offline
post #2 of 3 (permalink) Old May 23rd, 20, 9:41 PM
Jason
There are some good videos on you tube.
I don’t remember how I put mine on. But I watched a video.
Jasons 69 Chevelle is offline
post #3 of 3 (permalink) Old May 23rd, 20, 9:52 PM
Jason
The spring push’s agains the back side of the metal disc. Seems like it’s missing a pin. The red wire with the spring loaded pin pushes on the top side of the disc. The slotted hole goes over the tube. There should be a screw that grounds the horn cover to the adapter. I thought it was in the instructions.
