Wilwood upgrade Help? - Chevelle Tech
post #1 of 1 (permalink) Old Apr 11th, 20, 4:48 PM Thread Starter
Ron
Thinking about going with a brake upgrade with C6 Vette spindles and bearings and using the Wilwood Vette SLC56 front brake kit witch are 4 piston calipers and in the rear using the 4 piston kit with parking brake with 12.19 rotors.
My question is will the stock master cyl. and proportioning valve work or will I need to change one or both also?
ram396 is offline
