67 Chevelle front suspension - Chevelle Tech
 2Likes
post #1 of 17 (permalink) Old Apr 2nd, 20, 2:42 PM Thread Starter
Off frame restoreration, new springs, ball joint upper & lower. When I put it on the ground I have 1 3/4” negative camber. First time working on suspension. What is my problem??
Macau1$$ is offline
post #2 of 17 (permalink) Old Apr 2nd, 20, 5:25 PM
Freddy
Re: 67 Chevelle front suspension
Welcome to the site. Sorry, can't answer your question.
Freddy
Freddy Mercado is offline
post #3 of 17 (permalink) Old Apr 3rd, 20, 8:46 AM
Rich
Post some pictures. Is the car completely assembled? What are the details about the car? Big block, small block, what suspension parts were used, etc.
67_LS1 and Kirk's67SS like this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #4 of 17 (permalink) Old Apr 3rd, 20, 2:18 PM Thread Starter
350 Ci, All MOOG parts, everything was replaced new. Car sitting on the ground has about 13/4”negative, upper ball joint is at 15-20 degree angle, new springs ball joints upper, lower, tie rod ends, the works. It was body off frame.
Macau1$$ is offline
post #5 of 17 (permalink) Old Apr 3rd, 20, 2:26 PM
Rich
Is the car fully assembled, interior, all body parts, etc.? Did you tighten the upper and lower control arm bushing bolts BEFORE you put the car on the ground?
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #6 of 17 (permalink) Old Apr 3rd, 20, 2:27 PM
Mark
How is the camber being measured? Camber needs to be measured in degree's. I am not sure how you got 1.75 inches as stated in your post.Not trying to be rude, but just not understanding.
modern malibu is offline
post #7 of 17 (permalink) Old Apr 3rd, 20, 2:33 PM Thread Starter
Straight edge from floor to top of tire, placed ruler between tire and straight edge.
Macau1$$ is offline
post #8 of 17 (permalink) Old Apr 3rd, 20, 2:39 PM Thread Starter
I did tighten both upper and lower arms then I found out I should not have. I raised the car back up and loosened them and put it back on the ground.
Macau1$$ is offline
post #9 of 17 (permalink) Old Apr 3rd, 20, 2:42 PM Thread Starter
I appreciate your questions , I hope you can help.
Macau1$$ is offline
post #10 of 17 (permalink) Old Apr 3rd, 20, 2:44 PM Thread Starter
I’m don’t know how to post the pictures.
Macau1$$ is offline
post #11 of 17 (permalink) Old Apr 3rd, 20, 2:47 PM Thread Starter
Do not have fenders or doors on or interior on.
Macau1$$ is offline
post #12 of 17 (permalink) Old Apr 3rd, 20, 2:47 PM Thread Starter
Front doors
Macau1$$ is offline
post #13 of 17 (permalink) Old Apr 3rd, 20, 3:10 PM
How many shims on the upper control arm mount?
Sent from my SM-G930V using Tapatalk
msmith1.wa is offline
post #14 of 17 (permalink) Old Apr 3rd, 20, 4:35 PM
Randy
Until you get the car completely assembled with all curb weight on it, I wouldn't worry too much. Chevelle front end geometry will give a bunch of negative camber when it's not loaded. On the other hand, Chevelle frames are noted to sag especially big block cars, and will be difficult to align. Moog and others sell an offset cross shaft for the upper control arms to correct the problem, or you can take the car to a frame shop to correct the sag.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #15 of 17 (permalink) Old Apr 4th, 20, 9:14 AM Thread Starter
Thanks, I really didn’t think of the weight being part of the problem, but you are right.
Macau1$$ is offline
