Brake Hold off valve - Chevelle Tech
post #1 of 4 (permalink) Old Mar 25th, 20, 6:38 PM Thread Starter
This is a brake question I had because I was having issues bleeding my rear brakes using a new hold off valve I had purchased. On the 70s there is a rear hold off valve used to delay rear breaking and therefore preventing premature rear brake lockup. This is located in the back of the car right before the brake line tees and goes to the rear brakes.
Does anyone know what pressure this hold off valve is supposed to get too before allowing fluid flow and therefore rear brake engagement?
Thanks.
Oreo C is offline
post #2 of 4 (permalink) Old Mar 25th, 20, 8:59 PM
Re: Brake Hold off valve
Try this procedure
https://itstillruns.com/proportionin...-12040941.html
Billdini is offline
post #3 of 4 (permalink) Old Mar 25th, 20, 10:49 PM
Bruce
The first time I tried to bleed the brakes on my '69 I was forced to disconnect the front to rear line and blow it out with compressed air -- I was shocked when a wad of crap came out of the line. The line was totally blocked (and I'd just driven the car 11 hundred miles on Interstates)!
Just an idea "outside the box," so to speak.
Our You Tube Vids:
NickeyChevelle is offline
post #4 of 4 (permalink) Old Mar 30th, 20, 10:03 PM Thread Starter
Thanks for the info. I’ll be using both of your advice. Thanks.
Oreo C is offline
