69 PDB Problem - Chevelle Tech
post #1 of 14 (permalink) Old Feb 12th, 20, 12:52 PM Thread Starter
Really hard pedal, shop replaced booster w rebuilt booster, no better, replaced master cylinder, no better, replaced hard line across rear axle, better. Every time I mash brakes hard, brake warning light comes on.
Brakes not great, just OK.
I take car to Chevelle expert who I trust. I ask him to change proportioning valve on frame while he’s doing other work.
He says bad booster. He says rebuilt boosters very problematic. He says has replaced 3 rebuilt on same car, only uses new now.
Any comments ?
Is there a way to check my booster ?
Reelysalty is offline
post #2 of 14 (permalink) Old Feb 12th, 20, 8:17 PM
Bruce
Re: 69 PDB Problem
In this particular case, the Brake Warning Light indicates low brake line pressure -- that's a bad thing.
Is your system originally Power Brakes?
Are the lines original?
Are the lines the correct ones?
Have you bled the entire Brake Line System (the first time I bled my 'Bu's brakes I found that the rear line was plugged)?
Do you have the brake rod (between the Brake Pedal and the piston) in the correct hole (the lower hole as I recall for Power Brakes)?
Are you using the correct Brake Fluid?
What is the age/condition of the Wheel Cylinders (Don't even mess with a Wheel Cylinder Repair Kit, just get new ones, if you need them).
How about the Calipers?
Parking Brake/Emergency Brake hook up?
Personally, I'd go with a new Booster. I'd drain all the fluid out and then blow out the lines. Then I'd install a brand new booster (making sure to follow the instructions), I'd refill and bleed the system, making certain that the Caliper and Cylinders work "as advertised." Careful with the Brake Fluid -- that stuff is excellent paint remover!!!
"If your Brakes don't stop you, something else will."
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 14 (permalink) Old Feb 12th, 20, 9:05 PM Thread Starter
All work done by popular hi volume shop chain
Yes factory PDB
Some new lines are obvious
I can’t do brake work, no second person for bleeding
You would change out almost new booster ?
I read something about warning light reads “pressure imbalance”
Parking brake seems fine.
post #4 of 14 (permalink) Old Feb 12th, 20, 9:23 PM
You mentioned a proportioning valve on the frame. I believe 69 had a distribution block on the frame with a hold off valve attached to the master cylinder, at the booster. Do you have one if these valves on your car?
Johnny Bravo is offline
post #5 of 14 (permalink) Old Feb 12th, 20, 9:36 PM Thread Starter
Thanks,
Doesn’t look familiar,
I’ll have pics tomorrow
post #6 of 14 (permalink) Old Feb 13th, 20, 2:09 PM Thread Starter
Here’s the 2 distribution centers I have.
Engine has 15” at idle,
20” at 1250. Kicked idle to 1250 and drove around block, no difference in pedal.
ID:	616458   Click image for larger version
post #7 of 14 (permalink) Old Feb 13th, 20, 9:49 PM
That's the correct stuff. Maybe. Check your vacuum hose and see if it's either cracked, or possibly collapsing under vacuum. I don't know what your hose is plumbed into for a source, but check that too. It could be something simple like that. Does the pedal feel the same when the car isn't running?
post #8 of 14 (permalink) Old Feb 13th, 20, 10:13 PM Thread Starter
Vacuum hose plumbed into stock manifold port. Pedal feels about the same engine running or not.
When brake warning light plugged in, it glows brighter as I mash brake.
I can drain vacuum, keep foot on brake, crank engine and pedal will drop a little.
Good mechanic says I replaced booster with new, defective one. Could I, or rather could shop have replaced with new defective booster ?
post #9 of 14 (permalink) Old Feb 13th, 20, 10:37 PM
I guess it's possible. I have no experience with defective boosters, so I'm no help there. Have you checked to see if the Clevis on the rod coming through the firewall is in the lower hole on the brake pedal?
post #10 of 14 (permalink) Old Feb 14th, 20, 12:12 AM
Re: 69 PDB Problem
Was the brake warning light on when you first complained of the hard brake pedal ? and before any parts were replaced ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #11 of 14 (permalink) Old Feb 14th, 20, 12:56 AM
Dennis
Re: 69 PDB Problem
There is an adjustment screw or nut inside the booster. If that isn't adjusted properly that pin will be pushing the master cylinder plunger in and your brakes with always be engaged. I believe they call for about a 1/16" clearance. You might want to start there. But if that's a pro shop they should have already done that.
Too soon old and too late smart.
Progress is not always forward.
Sludge is offline
post #12 of 14 (permalink) Old Feb 14th, 20, 7:33 AM Thread Starter
Oddly enough, no
Warning light started coming on, just a faint glow at first after rear axle hard line was replaced and I got some braking restored.
I’m gonna check that rod position next
Thanks for all comments !
post #13 of 14 (permalink) Old Feb 14th, 20, 11:41 AM
Re: 69 PDB Problem
Have you replaced the rubber lines over the rear axle and front discs? Anything over 10-15 years old are suspect.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #14 of 14 (permalink) Old Feb 14th, 20, 6:10 PM Thread Starter
I think they were replaced.
