1970 Chevelle Upper and lower control arms - Chevelle Tech
 16Likes
  • 2 Post By oldcutlass
  • 2 Post By Malibu70
  • 1 Post By Kirk's67SS
  • 1 Post By cuisinartvette
  • 1 Post By hydro462
  • 3 Post By UMI Tech
  • 2 Post By shovelrick
  • 2 Post By s1nemesis1s
post #1 of 14 (permalink) Old Feb 1st, 20, 3:01 PM Thread Starter
Looking at these: https://www.ebay.com/itm/350457199342
I have a set of EIBACH PRO-KIT SPRINGS (SET OF 4) 68-72 SKYLARK / CHEVELLE / 442 / CUTLASS / GTO / LEMANS / TEMPEST - Manufacturer Part Number 3856.140. These springs are supposed to lower the car 1 inch on their own.
These control arms talk about:
“The geometry features include additional positive caster and a dropped spring pocket (approx 2" lower) compared to stock. The conventional lower coil spring pocket features a stamped steel pocket with a positive spring locating feature and nutserts for the shock lower attachment.”
I am still learning - I am sorry if this seems like a stupid question – but would these lower the car more?
Any good advantage over stock?
s1nemesis1s is offline
post #2 of 14 (permalink) Old Feb 1st, 20, 3:50 PM
Re: 1970 Chevelle Upper and lower control arms
Yes they will lower the car. In addition you get what you pay for, I would not put those on my car based on reports of similar ones failing for 1 reason or another. Compare similar items of other brand for price and how they are constructed..
Kirk's67SS and s1nemesis1s like this.
oldcutlass is online now
post #3 of 14 (permalink) Old Feb 1st, 20, 4:04 PM Thread Starter
Ouch! I will be careful then. I already have a good set of ball joints, I was going to replace the ones that came in these if I bought them. But if they are structurally unsound - no good at all! I would like a 3-inch drop I think, my Chevelle rides really high in the front...but this sounds like it might be dangerous.
post #4 of 14 (permalink) Old Feb 1st, 20, 4:33 PM
Frank
I see you have new springs and are looking for replacement control arms. The arms I want for my ride are the UMI tubular control arms with taller upper and lower ball joints. ($1400). These would improve the camber gain during cornering.
An option would be to retain the factory control arms, and install adjustable coil-over shocks to set the ride height to your liking. One product line is the QA1 stock mount coil-over system ($600). These can lower the front suspension height, but would not help the geometry of the factory arms that tilt the outside tire when cornering.
shovelrick and s1nemesis1s like this.
-Frank
1970 Chevelle Malibu purchased new in 1970
355 SBC, XE262H cam, Performer RPM heads, MSD HEI, TH200-4R trans, 3.55:1 Posi, digital gauges, QA1 coilovers
Malibu70 is offline
post #5 of 14 (permalink) Old Feb 1st, 20, 9:06 PM
Greg.
Agree with Frank about the UMI Perf Tubular Front Control Arms
as I bought their # 403133 Kit in 2012
and also bought the Viking DA Coil Over Kit # A205 from them
https://www.umiperformance.com/home/...-72-gm-a-body/
Great Ride/Handling and adjustablety of Ride Height/Stance
s1nemesis1s likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #6 of 14 (permalink) Old Feb 3rd, 20, 4:38 PM Thread Starter
Here is the response I got when I inquired:
Hi Donald!
Thank you for asking questions! These parts were manufactured in Taiwan and India. The brand is A-Resto-Parts. They meet or exceed all OEM Specifications. The are based upon the same molds and specs as Moog. If you would like to use them and if you need any replacement. We replace all parts from the date of purchase. If you would like to return them and get a refund, that is also an option. We haven't heard of any of our kits being dangerous or heard of anything dangerous happening while the car was operating, but if you would like to send the parts back, that is fine too. Please let us know what you decide.
Thank you
Jake
Andersen Restorations
post #7 of 14 (permalink) Old Feb 3rd, 20, 5:08 PM
We havent heard back from any of the fatalities, 100% rating!
cuisinartvette is offline
post #8 of 14 (permalink) Old Feb 3rd, 20, 5:44 PM
You want to check out the SC&C arms. The owner is an engineer who worked with Howe so his SPC arms can accept Howe regular and tall ball joints. They are some of the best joints in the business. They come apart and can be rebuilt so they last the lifetime, they can also be adjusted.. Only thing is Mark can be slow..
hydro462 is offline
post #9 of 14 (permalink) Old Feb 4th, 20, 8:02 AM
Good morning. Ramey here from UMI.
Thanks above, guys!
Our lower arms have the bucket in the stock location and have the ball joint moved forward ever so slightly to add caster. Our upper arms have a more aggressive balljoint relocation and really ups the caster (+2-3 deg nominal over stock). We also have tall ball joint selections for those arms.
For drop buckets in a-arms there's an attribute called motion ratio. A little bit at the bucket yields roughly double that at the fender. I'd imagine the offshore ones have around a 1" difference that gives the 2" outboard.
I'm happy to help with any tech questions you may have.
[email protected]
rw
UMI Technical Support
814-343-6315
UMI Tech is offline
post #10 of 14 (permalink) Old Feb 4th, 20, 8:26 AM
rick
OP those look very similar to the CA's I bought from ebay before I knew any better, I've replaced my ball joints with proforged and had to replace the rubber cushion because of a leaking MC (they use to come with rubber now they look like poly) speedtech was the only place I could find the correct size replacement cushion and in poly, my guess is those are made by speedtech no bashing here and I'm happy now that I've changed BJ's but if I were to do it again I'd go with a more known company like UMI (I have their sway bar) or something similar in quality, mine also had a removable 1/4" alum plate under the cushion to drop the front another 1/2"
shovelrick is offline
post #11 of 14 (permalink) Old Feb 6th, 20, 11:34 AM Thread Starter
Thank you all - including UMI! I will save some pennies and buy UMI when I can - it's worth it from reading here. I am debating though if I want to dump a bunch of money into my 4 door this way - or wait and get a 2 door and do it to that one. Right now I love my 4 door, but I know if I need to sell it....being a 4 door - as silly as it is - hurts the car So I am afraid to spend any money that won't benefit me directly on this car. At the same time the safety of others on the road as well as myself and my family is paramount - so I will wait and buy quality. I don't want to end up being one of the unreported fatalities LMAO! I just hope by the time I ready/can buy a 2 door project car I will be able to afford to buy it - and spend years working on it.
RAIDER SS and Kirk's67SS like this.
post #12 of 14 (permalink) Old Feb 6th, 20, 4:10 PM
rick
Crew cabs are cool too one that's well done would be worth more for resale with quality upgrades/parts, specially steering, brakes & suspension parts IMO
post #13 of 14 (permalink) Old Feb 17th, 20, 5:06 AM
UMI is known good stuff. put it on your 2-dr. 4-dr (IMO) is not worth doing this kind of stuff to. just update with new stock stock stuff. one thing you can do is put a 1.25" front anti-roll bar on the front. it's easily moved to the the 2-dr when you get it. Big difference in the car.
Tom Mobley is online now
post #14 of 14 (permalink) Old Feb 17th, 20, 9:37 AM Thread Starter
I don't have a 2 door yet to work with - I have the 4 door and will probably have it for the foreseeable future - I think she is cool. I would like a 2 door to work on, but I just cannot afford one right now (or any more cars lol). I can start looking next year about this time, I just hope I can still afford to buy a project car then - I don't think the 2 doors will skyrocket that much. I will be looking for one that is whole - it can be missing the motor and drive train, and have some rust, I just don't want a rusted out total hunk.
