front lower control arm dilemma - Chevelle Tech
 5Likes
  • 1 Post By oldcutlass
  • 1 Post By B52bombardier1
  • 2 Post By RAIDER SS
  • 1 Post By 454chevSS
post #1 of 10 (permalink) Old Jan 13th, 20, 2:08 PM Thread Starter
'66, stock resto but upgrading to "Chevelle" discs and 15 inch steel wheels.
I currently have 2 sets of front lower control arms (old, dirty/greasy), along with Moog rubber bushings (although I might only have the larger round bushings). I also have both Moog and ProForged lower ball joints.
Last year, after reading about old arms cracking at the BJ, I finally decided to buy new, repro lower arms... So I now have the set of new, repro arms (non-returnable based on when I purchased).
Has anyone had a problem with, or heard of a problem with the STOCK repro lower arms or BJs? I know I have heard of BJs breaking in the imported tubular arms, but nothing about "stock" repro arms.
Removing the stock arms yesterday, I noticed some minor damage (scraped on edge but not bent), and looks like damage from the steering arm tail hitting the arm (odd because its a low-mileage, manual steering car)... Come to think of it, my other set of arms might have have a loose BJ at one time (not sure if I can identify that set now).
So the dilemma is to:
  • rebuild the stock arms (50+ year old) with the new BJs & bushings
  • use the repro lower arms as-is
  • Use the repro lower arms, but with new Moog or ProForged BJs
TC #1366
Sold
Sold
1966_L78 is offline
post #2 of 10 (permalink) Old Jan 13th, 20, 4:35 PM
Re: front lower control arm dilemma
Since you have the repro arms, use them with the new Moog or ProForged ball joints. Both manufacturers are quality parts.
OLDED likes this.
oldcutlass is offline
post #3 of 10 (permalink) Old Jan 13th, 20, 4:50 PM
I went with repro control arms and all Moog replacement parts and I've been very happy so far. The front end alignment numbers that I chose for my 70 El Camino were for a 1974 Monte Carlo and I'm very happy with the steering performance. The alignment technician used a completely normal number of shims to get me to the Monte Carlo alignment specs. It also very much helps that I'm running a mid to late 90s steering box out of a Jeep Grand Cherokee.
A great big hydraulic press is needed to get the A-arm bushings in!!!
hydro462 likes this.
B52bombardier1 is offline
post #4 of 10 (permalink) Old Jan 13th, 20, 5:18 PM
Greg.
Where are the New Repro Lower Arms manufactured ?
I replaced my Front Upper & Lower Control Arms with UMI Perf Tubular ones
https://www.umiperformance.com/home/...front-arm-kit/
Alignment Tech said they were easy to adjust & very few Shims needed
I think UMI now has Adjustable Upper ones that do not need/or very few Shims
https://www.umiperformance.com/home/...ms-adjustable/
https://www.umiperformance.com/home/...r-ball-joints/
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #5 of 10 (permalink) Old Jan 13th, 20, 5:24 PM
A great big press is not needed, just a hammer and an old large socket or piece of pipe. The specs most of use for alignment are:
As much positive caster that we can get
.5* negative camber
1/16 toe in
post #6 of 10 (permalink) Old Jan 13th, 20, 9:02 PM
Rob
I have checked several of the repo / restoration parts vendors and all have come back overseas or tiawan,,, been on the fence which to go with or go tubular but for just a street cruizer ...
454chevSS is offline
post #7 of 10 (permalink) Old Jan 13th, 20, 10:41 PM
David
IMHO - If you have low mileage original control arms from a non-rusty CA car; I would reuse them.
That's what I'm doing
LKN BCK and Pete 67 like this.
66 Malibu......back to life, now with a 427 BB & 4 speed
RAIDER SS is offline
post #8 of 10 (permalink) Old Jan 14th, 20, 9:13 AM
I never regret installing the SC&C Stage III set up on my 69 el Camino.. That along with the Lee 14:1 30 pound steering box were the best money spent on my car so far...
I love tooling through the twistys with two hands on the wheel because of the positive feedback of the box..
Yesterday, while thoroughly enjoying my drive, I was thinking what makes Marks SPC set up so great is the use of Howe modular ball joints. Mark had Howe specially make these up for him and its the only place you can get them installed in a SPC custom adjustable control arm..
hydro462 is offline
post #9 of 10 (permalink) Old Jan 14th, 20, 10:26 AM
Greg.
IMHO using 50+ year old parts that carry the Load of the Front of the car and Steer the car around corners
is not what I would want to fail anywhere anytime
EG. a curvy Mountain Road
on a Hwy going 70+ mph
on a City Street when needing to Stop quickly for whatever Reason
I was amazed at the Build Quality of the UMI Perf Suspension Parts that I have bought
It is to bad/sad that some American Company has not taken up the challenge to build good Original type parts for our old cars
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #10 of 10 (permalink) Old Jan 14th, 20, 8:08 PM
Rob
So true, after reading through and seeing other members posts with control arm letting go either backing out of driveway or one I recall while driving. Has me very reluctant on doing just bushings on mine.As soon as I noticed my lower bushing chewed up(and it was by fluke) car has been parked ever since
Kirk's67SS likes this.
