Another hard pedal problem - Chevelle Tech
 2Likes
  • 2 Post By Reelysalty
post #1 of 11 (permalink) Old Jan 5th, 20, 1:07 PM Thread Starter
I know that this problem has been addressed many times, but I'm not getting to the solution so I appreciate any help. I installed front discs on my 69 Chevelle in 2003 and until about 6 months ago haven't had any issues at all with them until the hard pedal showed up. Since I don't drive it more than 1-2 times/month it wasn't obvious exactly when it started. Now its hard to hold at idle and trying to power brake is practically impossible. Chevelle has about 5,000 miles since full restoration. I also have a daily driver 71 El Camino with basically the identical setup so I have an easy comparison to properly functioning brakes.
Immediately I looked at the check valve and replaced it since I had a new one that was fine - no change. So the booster was the obvious issue and I replaced it - no change. When I installed the booster I adjusted the clevis to be about the same position as the old one, but never thought this adjustment really matters. Now I'm not so sure and would like a description on how to adjust it and if it might be part of my problem.
I then tried to reset the proportional valve, although I've never heard of that before - no change. For fun, I did the standard tests on the El Camino and they were fine and I popped off the check valve after running it and for sure have vacuum stored after the engine off. Repeated it by hooking up the old booster with the same result leading me to believe it may be fine. Went to the Chevelle and did the tests but the pedal didn't drop when I started the engine, but after shutting it off I popped the check valve and had vacuum stored so no big leaks and check valve OK.
Then I saw this post and tried to space out the master with washers about 0.22" - no change but I also don't have any idea why this matters or how much to space it out. What the hell could be wrong with this brake system? Any advice would be great, I'm at my wits end on this one and would really love to drive this car again.
eduardo69chevelle is offline
post #2 of 11 (permalink) Old Jan 5th, 20, 2:55 PM
Re: Another hard pedal problem
Have you measured how much vacuum you have at the booster? Mine fails below 14PSI. You said it was fine for 6 month so that eliminates that you didn't use the right rod for the master cylinder. It's fairly simple that a master with a recessed rod piston uses a long pin and a slightly flat with little recess uses the short. Some rods are adjustable and some if not correct require grinding. The importance is if the master cylinder piston can't be allowed return back to its normal operation position the fluid gets trapped and doesn't cycle which causes heat lock resulting with a hard peddle and poor braking. This only occurs after the fluid heats up though. I assume when you stated you did all the normal checks that included wheel cylinders actuate when the pedal is depressed. To me it sounds like you have a blockage possibly in the master cylinder itself. Good luck troubleshooting
Billdini is online now
post #3 of 11 (permalink) Old Jan 5th, 20, 4:14 PM
Since it was working, and now suddenly it isnít not, verify that you are getting good fluid flow at all 4 wheels. A frozen wheel cylinder or caliper or collapsed rubber hose could be not allowing any fluid to pass, which will give you a hard pedal too.
lucifershammer is offline
post #4 of 11 (permalink) Old Jan 5th, 20, 6:34 PM Thread Starter
Yes, it was perfectly fine for 16 years and only the last 6 months has been acting up. I measured the depth of the hole for the rod in the MC at around 1-3/4" so it must be the longer rod just like the one that was in there for 16 years. Nothing changed in the engine during that time that would impact the vacuum but it is probably low due to the cam but I'll check it.
Forgot to mention that I jacked up front and rear and checked that all the brakes were working, but that is only enough to stop it rotating with my hands so not necessarily a good test.
I'll say I never thought the MC could be the problem and hate the idea of changing it unless its bad. The collapsed rubber hose is also a new idea that I'll have to check and get back to everyone on it. Probably will be next weekend before I find time now but thanks for the ideas. Does this rule out the proportional valve?
post #5 of 11 (permalink) Old Jan 7th, 20, 5:00 PM Thread Starter
Just did a vacuum check, both the El Camino and Chevelle are idling right at 15 inches and pretty solid. Given that the El Camino is working fine there is no way in my mind that the vacuum is the problem. In a few days I'll get to checking the rubber hoses and report that back.
Suggestions on how to verify I have good flow at each wheel? All I did was rotate the wheel and have someone push the brake to verify it locked the wheel - is that good enough?
post #6 of 11 (permalink) Old Jan 7th, 20, 11:43 PM
leo
Your problem isn't at the wheels, it lies at the booster. Maybe the vacuum hose to the booster has collapsed internally, Good luck!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is online now
post #7 of 11 (permalink) Old Jan 11th, 20, 12:25 PM Thread Starter
I also think its at the booster given the symptoms. But, just to be thorough I inspected all the flexible lines and they seem fine - only about 4 or 5k miles on the cars since resto but 18 years. Anyway, no cracks, collapsed, or leaks anywhere in the system under the car.
Back to the booster/master cylinder/prop valve. Can someone offer opinion about whether hard pedal could be ANYTHING other than the booster or vacuum?? I just redid my vacuum check by removing the check valve at the booster to rule out anything else and see around 14" (had 15" on the line to the distributor). The hose seems fine and I know the check valve is fine.
I'm back to the booster itself. If the booster holds vacuum does that means its OK or not necessarily? I did a test where I ran the engine for a minute, shut it off, and after a few minutes pulled the check valve and there was strong vacuum and seemed the same as the El Camino. Also, the old booster I removed acts the same way.
But the damn pedal doesn't move at all when I start the engine (El Camino moves 1/2 - 3/4") and if I drive with or without the vacuum connected there is NO difference. Gotta be a 2nd bad booster, right?
post #8 of 11 (permalink) Old Jan 18th, 20, 1:59 PM Thread Starter
Anyone? I'm going to put in a 3rd booster today because I can't imagine anything else causing this. Is there something else I should be looking at?
Like I asked on the last one - can someone offer opinion about whether hard pedal could be ANYTHING other than the booster or vacuum?
Thx, Ed
post #9 of 11 (permalink) Old Jan 18th, 20, 11:13 PM
I had a blocked hard line over rear axle cause hard pedal.
67_LS1 and lucifershammer like this.
Reelysalty is offline
post #10 of 11 (permalink) Old Jan 19th, 20, 12:07 AM
What brand Power Booster are you using?
blue_69_malibu is online now
post #11 of 11 (permalink) Old Jan 19th, 20, 11:27 PM
Ben
Howís the pedal not running? Still hard? If they are comparable, Iíd swap the el Camino booster to the chevelle and see what happened. Thatíd rule in or out the booster.
No car yet; currently looking for 66-69 project/driver.
skreddy is offline
