Speed tech Frame connectors? Anyone use - Chevelle Tech
 4Likes
post #1 of 16 (permalink) Old Dec 7th, 19, 5:35 PM Thread Starter
Anyone ever use this product?
I'm having problem with frame twist on my
66.
https://www.speedtechperformance.com...rod/prd398.htm
66 chevelle in the works
Team Chevelle Member #:2361
In God we Trust! USA
66dream is offline
post #2 of 16 (permalink) Old Dec 8th, 19, 9:23 PM
Dennis
Re: Speed tech Frame connectors? Anyone use
Im sure these guys know what their doing. The kit looks well thought out.
My 2 cents is that the biggest improvement is due to boxing the frame.
66 Chevelle hardtop - LFX 3.6 liter 4 Cam V6/6L50 6 speed auto trans, 3.07 10 bolt, full Hotchkis suspension, Wilwood 4 wheel discs, white with red interior, cowl hood.
67_LS1 is offline
post #3 of 16 (permalink) Old Dec 9th, 19, 7:28 PM Thread Starter
I was hoping someone else had tried this kit or simular kit, particularly without removing the frame from the body.
Any other feedback or opinions welcome
66dream is offline
post #4 of 16 (permalink) Old Dec 9th, 19, 9:12 PM
Troy
I recently boxed in the frame on my 66, it was removed from the body though. It's not any where nere back together but I'm expecting great things.
I used the Hellwig kit.
https://www.chevelles.com/forums/11178908-post127.html
66 CHEVELLE
senna is offline
post #5 of 16 (permalink) Old Dec 9th, 19, 9:31 PM
Dennis
That looks good. Way stronger looking. Is that painted or powder coated?
67_LS1 is offline
post #6 of 16 (permalink) Old Dec 9th, 19, 9:52 PM
Troy
Powder coated
66 CHEVELLE
senna is offline
post #7 of 16 (permalink) Old Dec 9th, 19, 10:33 PM
I like it with the exception of the hoop that bolts to the body floor. That part looks like it can be problematic. A boxed frame is where most of the strength is not those cross bars. I agree a chassis without the body bolted on is pretty flimsy, the body adds a lot of strength to the assy as a whole.
oldcutlass is online now
post #8 of 16 (permalink) Old Dec 10th, 19, 7:43 PM Thread Starter
Thanks for the feedback guys. What is it about the hoop bolting to the floor that you disllike?
66dream is offline
post #9 of 16 (permalink) Old Dec 10th, 19, 8:50 PM
Because the frame and the body are isolated by rubber bushings and flex but parts ( I noticed in the pictures there are 2 other bolts directly to the floor) of the added on reinforcement are bolted to the floor directly. I would think that it may create cracks in the floor pan and/or noise/vibrations.
shovelrick and 67_LS1 like this.
post #10 of 16 (permalink) Old Dec 11th, 19, 10:47 AM
Troy
I would think those additional mounts go to the floor braces, which is a much thicker gauge of metal.
I would also think once the the frame is boxed the flexing would be minimized to the point of no issues with squeaking.
That being said, I wasn't fond of the center hoop for my lowered car with a LS/T56 conversion as I raised the tunnel all the way back to the rear portion of the seat pan to make sure the driveshaft didn't rub.
I also felt the flat plate boxing as opposed to the C type that mimicks the way the factory did it that Hellwig uses is a much stronger style of boxing. But probably not an option for installing with the body still attached,
Sent from my SM-T720 using Tapatalk
66 CHEVELLE
senna is offline
post #11 of 16 (permalink) Old Dec 18th, 19, 12:25 PM
I think the difference in strength of the flat plate boxing and the c channel boxing like the hellwig kit is negligenable
Binford is online now
post #12 of 16 (permalink) Old Dec 23rd, 19, 7:56 AM Thread Starter
ok, so looks like this Speedtech kit would work.
Has anyone tried one of these lifts?
https://leavesslave.top/products/car...e6PhBKBUBq1pvw
66dream is offline
post #13 of 16 (permalink) Old Dec 23rd, 19, 10:30 AM
Dennis
Ive never used a lift like that but I would be scared of that website. $89 for the lift?????
davewho1 likes this.
67_LS1 is offline
post #14 of 16 (permalink) Old Dec 23rd, 19, 11:06 AM
I would be very leery of that site - it was only created 16 days ago, and has no valid https:
https://www.scamvoid.net/check/leaveslave.top/
https://www.scamfoo.com/site/leaveslave.top/
They are also claiming that they have free shipping. Shipping something like that will cost at least $300 - for an $89 item. It is a scam site - use at your own risk.
Just did some further checking. The address is shown as being in Phoenix, AZ, yet the phone number has a 347 prefix (Arizona is 480, 602, 520, and 928). Further investigation shows it to be located in "Asia Pacific".
My Chevelle w/ open headers:
1971-Chevelle is online now
post #15 of 16 (permalink) Old Dec 25th, 19, 9:51 AM
A close friend of mine has had a similar lift made by Mohawk for 8-10 years. It was considerably more money fwiw! He routinely lifts his 1975 Laguna S3 on it to get the body/chassis up at comfortable work height which it does with ease. It does not allow access to exhaust and transmission etc.
USAF Retired (1968-1988)
David Bates is online now
