hydroboost no accumulator ? - Chevelle Tech
 15Likes
  • 2 Post By senna
  • 3 Post By red68chevL
  • 2 Post By Old Bear
  • 3 Post By OLDED
  • 2 Post By GoFast Beaumont
  • 1 Post By Hotwire
  • 2 Post By jackie schmidt
post #1 of 11 (permalink) Old Nov 29th, 19, 11:24 PM Thread Starter
jim
im looking at a used hydroboost unit. it has no accumulator on it ,all the units i see have one on it.
i understand i will have a hard brake pedal without the motor running . are these units any good ?
it has the billet firewall plate and braided line kit . thanks
jpvelle is offline
post #2 of 11 (permalink) Old Nov 29th, 19, 11:43 PM
Troy
Re: hydroboost no accumulator ?
From what I understand, without an accumulator if you lose engine power there is no reserve boost to assist stopping the vehicle.
OLDED and BillyGman like this.
66 CHEVELLE
senna is offline
post #3 of 11 (permalink) Old Jan 10th, 20, 8:52 PM
I am in the middle of taking my Hydro out and replacing it with a regular booster and MC. My carb would load up, now rebuilt, and I wouldn't have any brakes once the car stalled. Hated this system. I don't know why someone would want this type of system. It scared me when I had nothing as far as brakes.
Cambird is offline
post #4 of 11 (permalink) Old Jan 11th, 20, 12:03 AM
Eddie
I have hydroboost on my Cutlass. I've been having some issues with ignition and engine shut off few times on me when I was test driving, I had no issues stopping the car. The pedal was normal, not hard at all, actually I didn't even think about it until I've seen this thread.
Eddie K is offline
post #5 of 11 (permalink) Old Jan 12th, 20, 8:17 PM
Eddy I absolutely hated the system. It was on the car when I bought it. Either mine was faulty or it wasn't hooked up correctly. Either way its off the car. I have a small block, disc from drum rear so I didn't see the need for it. Its not like I didn't have any vacume and needed this system. If anyone wants one, let me know, send me an email.
Cambird is offline
post #6 of 11 (permalink) Old Jan 12th, 20, 10:57 PM
This is really stunning. I put one on my car for the exact reason you complain about it. I had a really hard pedal with the vacuum Booster, had a SBC 327, big cam, low speed vacuum was terrible. Hydroboost completely solved the problem.
David Bates, OLDED and Old Bear like this.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is online now
post #7 of 11 (permalink) Old Jan 13th, 20, 1:00 AM
Gale & his cats
JPVelle
I would look for a unit with the accumulator.
Here is a discussion on switching to Hydroboost.
Conversion to Hydro Boost Brake System - 1970 El Camino
https://www.elcaminocentral.com/thre...3#post-2513942
Here is a discussion on Cutlass and hydroboost.
https://www.chevelles.com/forums/16-...ss-unreal.html
Maybe there is a solution for CamBird there. Possibly in discussions about pedal leverage fulcrum and bore sizes.
Old Bear - Doing fine with my hydroboost conversion.
David Bates and red68chevL like this.
Old Bear is online now
post #8 of 11 (permalink) Old Jan 13th, 20, 6:27 PM
My hydra-boost is maybe the best driveability improvement I've done to my 65. You do need a unit with the accumulator. I use a unit from an Astro Van and a pump from a 3500 Van - with 2 return nipples. I used stock mid 80's Buick Le Sabre pressure hoses for the diesel engine and they are a direct fit.
David Bates, red68chevL and MarkP like this.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #9 of 11 (permalink) Old Yesterday, 2:08 PM
having had a recent major engine failure I would strongly recommend against this purchase. I too have a hydro-boost system. my engine failed at approx. 80mph, I would have liked to stopped faster. As a result I picked up a new hydro-boost with a oversize accumulator, it came off a 2005 Yukon XL.
71350SS and Hotwire like this.
1968 Beaumont
502 big block
HP and ET not determined yet!
GoFast Beaumont is offline
post #10 of 11 (permalink) Old Yesterday, 3:54 PM
Exact same one I'm running on my 64, big accumulator. Have had my engine stall on me a couple times while tuning it but has been nothing but awesome since then. Running sticky 255/40/17s with cheap pads and stock 70's style rotors, can easily pick you up out of the seat or completely lock them up.
71350SS likes this.
*Jeff*
LQ4 / T56 Swap
Hotwire is online now
post #11 of 11 (permalink) Old Yesterday, 9:57 PM
jackie
Just get a Hydo-Boost with the accumulator. Problem solved.
I love my Hydro-Boost.
jackie schmidt is offline
