UMI rear sway bar 70 Malibu - Chevelle Tech
  • 1 Post By WakkoWarner
post #1 of 13 (permalink) Old Nov 17th, 19, 8:52 PM Thread Starter
I bought an umi setup a while back. FINALLY getting around to getting the trailing arms on, and it came with a rear sway bar. Is there some trick that I'm missing. The holes closer to the front of the car line up fine, and when I get it tightened , the rear holes are about 1/4 inch off. Any suggestions or knowledge I'm missing? Calling tomorrow if nothing here.
Jlhook716 is offline
post #2 of 13 (permalink) Old Nov 17th, 19, 11:46 PM
Re: UMI rear sway bar 70 Malibu
Keep the bolts loose until you have them all installed and the nuts started, then tighten them up. Mine went right in with no issues at all.
Kirk's67SS likes this.
My Chevelle w/ open headers:
WakkoWarner is offline
post #3 of 13 (permalink) Old Nov 18th, 19, 12:50 AM Thread Starter
Tried it, the bend in the bar wont allow me to put all 4 in.
post #4 of 13 (permalink) Old Nov 18th, 19, 11:03 AM
Greg.
I had no problems with the ones I bought from UMI Perf
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #5 of 13 (permalink) Old Nov 18th, 19, 11:19 AM
Its possible you have lower control arms that weren't originally boxed and drilled. Previous owner may have drilled the holes incorrectly.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #6 of 13 (permalink) Old Nov 18th, 19, 11:38 AM
You could just go purchase some slightly longer bolts. Could you post a couple of pictures to give us a better idea of what you are dealing with??
post #7 of 13 (permalink) Old Nov 18th, 19, 11:47 AM
rick
They sell shims if the bar isn't close enough to the LCA, if you pull them in your bending the LCA's
shovelrick is online now
post #8 of 13 (permalink) Old Nov 18th, 19, 1:23 PM
Greg.
Please provide the Kit #
or
the individual Part #s you bought
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #9 of 13 (permalink) Old Nov 18th, 19, 10:11 PM Thread Starter
https://www.umiperformance.com/home/...trol-arms-kit/
Bought that and this.
https://www.umiperformance.com/home/...ering-stage-1/
Rear sway bar doesn't bolt up. I got in touch with the UMI rep on here and he sent me a measurement diagram. When I get off work tomorrow I'll get pics and measure it up.
post #10 of 13 (permalink) Old Nov 18th, 19, 10:12 PM Thread Starter
One thing is there a different bar for boxed trailing arms vs tubular?
post #11 of 13 (permalink) Old Nov 18th, 19, 10:30 PM
Not that I know of, the only other bar they sell is a frame mount. I'm waiting to see what happens as I'm thinking of the similar kit for a 67.
oldcutlass is online now
post #12 of 13 (permalink) Old Nov 18th, 19, 11:56 PM
I have 1969 12 bolt with factory boxed lowers on my 1967 300 Deluxe I bought the UMI rear sway bar and had to put all bolts in then tighten as at first they didn’t line up when I tightened one side the other side lined up
Bradco is offline
post #13 of 13 (permalink) Old Nov 19th, 19, 12:23 AM Thread Starter
This is what I've been wanting to hear. I'll torque the top 2 down correctly and see if that lines up the others.
