Alignment how to? - Chevelle Tech
 16Likes
post #1 of 18 (permalink) Old Nov 11th, 19, 10:57 PM Thread Starter
Rame
Alignment how to?
I'm all about using local services but my local shop sucks....bad. Next closest place is over 40 miles away. Can someone give me a tutorial on alignment and the tools i would need? I know this sounds silly but I would rather buy the tools and do it myself. Any info would be appreciated.
sampoerna415 is offline
post #2 of 18 (permalink) Old Nov 11th, 19, 11:16 PM
Re: Alignment how to?
The tools aren't super expensive (relative) but knowing how to use them effectively can be the problem. I'm a former chassis tech and had a ton of experience with laser equipment so I had a better starting point than most. I bought a Tenhulzen setup for around $500 a few years ago and it's about paid for itself since. It's plenty accurate when used correctly.
Local shops that suck are exactly why I bought my own stuff, also. As far as where to start- it's caster, camber, toe, in that order. I can help guide you through it but I don't really have a tutorial handy. I have a diverse stable of junk and each one adjust differently but the order is always the same.
David Bates and sampoerna415 like this.
70 Camino...Roller
Tommy the Cat is offline
post #3 of 18 (permalink) Old Nov 11th, 19, 11:18 PM
First off you need an alignment gauge setup.
Longacre Alignment Tools
sampoerna415 likes this.
oldcutlass is offline
post #4 of 18 (permalink) Old Nov 12th, 19, 8:50 AM
I've been looking hard at Quickturn Alignment system for my cars.
https://www.speedwaymotors.com/Quick...ms,375872.html
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #5 of 18 (permalink) Old Nov 12th, 19, 8:54 AM
You will need a level spot for all four wheels. Then four 12 x 12 pieces of sheet metal, make two sandwiches with grease in the middle. Place these in front of the front tires and push the car onto them just using the parking brake to stop the car. These will let the suspension relax and you will get a better reading..
I use a small angle finder to check camber and caster... https://www.regulustlk.com/products/...le-finder-tool
Then I have a piece of Kindorf with two 6" long 1/4" screws ground to a sharp point. These come out right were the center of the front tire is.
First I place this behind the front the tires and set the points exactly in the center of both tires, then move it to the front and take a reading. This will show if I'm toed out or in..
They sell some real nice set up today. I would also look into one of them. The Fast Trax seems to be popular..
bry66 and sampoerna415 like this.
hydro462 is offline
post #6 of 18 (permalink) Old Nov 12th, 19, 2:35 PM
Bryan
I make a couple of grease sandwiches out of scrap sheet metal just like Jeff described in post #5 above, and set my caster and camber using a FasTrax gauge I bought from Summit Racing (side note...for the price, you only have to do two of your own alignments and this thing has paid for itself, here's the link: https://www.summitracing.com/parts/sps-91000/overview/).
I'm sure there's a better way to set the toe. But I just tie a long piece of string to a couple jack stands and get it perfectly parallel to car relative to the center of the front wheel and the center of the rear wheel. Then, using the string as a reference, use a tape measure to get 1/16" or 1/8" toe in or whatever you're shooting for.
sampoerna415 and hydro462 like this.
'66 SS Clone
Fast Burn 385hp Crate 350 (for now)
Muncie M20 & 3.42 Posi
UMI Stage 2 Suspension all around
bry66 is offline
post #7 of 18 (permalink) Old Nov 12th, 19, 3:29 PM
Not trying to dump on you and you're on the right track but the proper way to do what you're trying to do is to have two devices that are exactly the same length, one at each end of the vehicle and perpendicular to the vehicle. You then run your string parallel to the vehicle and center the perpendicular devices relative to the frame (preferred) or center of the wheel at that end of the vehicle.
The reason for this is because the front and rear track widths are almost always different. If you're running a string parallel to the centers of the wheels on just one side the string will not be parallel to the center of the vehicle due to the different track widths and thusly your toe won't be accurate.
You could easily use 4 jack stands with equal length electrical conduit pipe at each end with the string between them. The important part is that you're square with the center of the vehicle and not the axles/wheels, unless you know for fact that your axle is square and your track width is identical front to rear.
Am I making any sense?
70 Camino...Roller
post #8 of 18 (permalink) Old Nov 12th, 19, 6:41 PM Thread Starter
Rame
thanks for the reply's everyone, figured it couldn't be that complicated, time to buy more tools.
post #9 of 18 (permalink) Old Nov 12th, 19, 7:44 PM
Bryan
Makes perfect sense, I like the conduit idea. Wish I would have thought of that and Iíll probably do it this way next time.
'66 SS Clone
bry66 is offline
post #10 of 18 (permalink) Old Nov 12th, 19, 8:21 PM
jeff
I have used white spray paint and a tape measure for many years and eyeballs.
Some cars may sit too low for the tape measure.
set toe by measuring front and rear of the front tires.
Set camber by spraying a white line across the tire tread and roll down the road in a straight line.
You must have the car pointing straight and NO turning. roll 50-100 yards or so and see where the paint wore off the tread. Adjust camber until it wears even.
That has been my poor boy way for decades.
You can play with more or less caster and see how you like the way it drives.
sampoerna415 and SSJohn like this.
jeff swisher is offline
post #11 of 18 (permalink) Old Nov 12th, 19, 9:48 PM
I use a Longacre caster camber gauge with magnetic mount. You must use a wheel that allows access to the center of the rotor, not a SS wheel. Directions that come with the gauge are easy to follow. Use something long to line up the gauge with the body of the car when doing caster readings. I use a 4 foot level but any straight edge will do.
sampoerna415 and jeff swisher like this.
25C 70 is offline
post #12 of 18 (permalink) Old Nov 13th, 19, 4:24 AM
I used a Longacre caster camber gauge, a bar type toe gauge I got from Crutchfield back in the 80's, a set of jack stands and a ruler and some string. I haven't verified my alignment with a shop, but it seems to be spot on by the feel of it. I posted about it a few months ago. The only problem I ran into when doing it was the rabid fox that wandered into my shop while I was doing it.
https://www.chevelles.com/forums/16-...-69-today.html
Another tip is to put some kind of thick plastic sheet under the tires so turning them is easy. I cut a couple pieces from some plastic sheets that are used to cover wire metro racks.
ZZ69chevelle is offline
post #13 of 18 (permalink) Old Nov 13th, 19, 8:01 AM Thread Starter
Rame
I put freezer tape on the treads of the tire anytime I mess with the suspension to see if it need to be realigned does the same as the paint so I'm right there with you on poor boy methods just never tried any adjustment myself, thanks for the tip.
post #14 of 18 (permalink) Old Nov 13th, 19, 8:45 AM
Rich
I have a FasTrax and it works very well. You have to have a relatively level spot to do the alignment and then FOLLOW THE DIRECTIONS. It is very important that you do things methodically and completely and in the right order.
https://www.summitracing.com/parts/sps-91025
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #15 of 18 (permalink) Old Nov 15th, 19, 5:32 PM
Geoff
Yup....X2
Geoff1200 is offline
