vacuum booster upper or lower brake pedal hole - Chevelle Tech
post #1 of 4 (permalink) Old Oct 25th, 19, 7:40 PM Thread Starter
I have a 1972 Chevelle ss clone
Just changed the vacume booster to a shiny new one
Does the booster arm go into the upper or lower hole in the brake pedal
Don't remember which way it was when I took it out
Thanks Again
8453johng is offline
post #2 of 4 (permalink) Old Oct 25th, 19, 8:04 PM
J
Re: vacuum booster upper or lower brake pedal hole
The booster bracket should mount it at an angle that aligns the pedal rod with the lower hole. Have you mounted the booster and is the rod aligned with the lower hole?
NorCal-SS is online now
post #3 of 4 (permalink) Old Oct 25th, 19, 11:38 PM
As stated above, the rod goes to the lower hole. Its almost physically impossible to go to the upper hole. The upper hole is for manual brakes with no booster.
oldcutlass is offline
post #4 of 4 (permalink) Old Oct 26th, 19, 12:10 AM
Claude
Since I've added a hydroboost system, I used the upper hole for a more effortless brake pedal.
Claude.
1971 Chevelle SS
toofastforyou is offline
