Lee 12:1 box getting sloppier - Chevelle Tech
  • 1 Post By Pioneer4x4
post #1 of 9 (permalink) Old Sep 26th, 19, 12:10 PM Thread Starter
Lee wants me to buy another one, in short
Has 60 miles on it gets sloppier the more I drive it
Everything under it is new/tight, new rag joint even rebuilt the column
How can I adjust this thing moneys not flowing yet
If i had to replace it whats a good bolt in box where my lines etc will bolt right up?
This thing wasnt cheap not real happy with it.
First 30 mi worked great.
67 EC
cuisinartvette is offline
post #2 of 9 (permalink) Old Sep 26th, 19, 1:31 PM
Jason
Weird.(possibly it’s air in the lines) When was it built? Was it bought directly from Lee? Can you post a couple pictures of the box. I bought mine years ago from the old man a few years before they shut down and reopened. Have someone video the shaft turning and the box not responding if possible to verify it’s the box.
Jasons 69 Chevelle is offline
post #3 of 9 (permalink) Old Sep 26th, 19, 1:38 PM
Re: Lee 12:1 box getting sloppier
JGC swap, simple, cheap, you can get everything but the lines/adapters in a junk yard for WAY under $100. Heck, for $50 you can probably get them to pull it, I did.
If you swap the pump port to the new style you can use off the shelf Camaro pressure line, and use the fitting from the Jeep for the return line.
B52bombardier1 likes this.
Pioneer4x4 is offline
post #4 of 9 (permalink) Old Sep 26th, 19, 1:49 PM
Have somebody turn the box right and left very slightly while on center using the mark Lee puts on the shaft... Make sure its the box.. Or find a way to lock the pittmen arm with vice scripps while on perfect center. Then turn the wheels slightly and see how much play there is..
Lee was very interested in how things went with my box swap and if I was happy with everything.. They called me a couple times asking if I was happy with there box..
hydro462 is offline
post #5 of 9 (permalink) Old Sep 26th, 19, 2:12 PM
Jason
Make sure the adjustment screw hasn’t moved. You can see the yellow marks should line up.
post #6 of 9 (permalink) Old Sep 26th, 19, 2:50 PM Thread Starter
Pn for a ready to go box?
honestly lee was an ahole from day 1
I brought him my box and a F body from the junyard like he wanted, took months charged almost 5 bills and was rude.
Yrs later when I got it running and noticed the slop I simply called and asked him what I can do to fix it myself. Nothingelse
Right off the bat he starts yelling/swearing and wanting another $500 and Id have to wait months"Take it or dont" and hung up on me.
post #7 of 9 (permalink) Old Sep 26th, 19, 5:10 PM
I did the JGC conversion about 6 years ago or 6000 miles myself with limited mechanical experience . Haven’t noticed any change. Sounds as if Lee changed the “T” bar and worm gear. Did you stay with your old 13/16” input and coupler that the 67 ElCamino used? Maybe the locking nut on the top of you pitman shaft moved, allowing slop between the worm gear and the pitman shaft teeth?
There is a way to retain an original gear box, cover, and pitman shaft when doing the JGC swap
Jim_66SS is offline
post #8 of 9 (permalink) Old Sep 26th, 19, 5:14 PM Thread Starter
Yes I bought it in person from him.
Brought him my original and a trans am junkyard box like he wanted still paid 5 bill (May have been 4 and change)
Many years ago.
I just want to know if I Can somehow adjust this thing without taking it to anyone, thanks.
post #9 of 9 (permalink) Old Sep 26th, 19, 6:09 PM
Yes, you adjust using an allen wrench in the top of the cover. Loosen to lock, turning the allenwrench pulles the pinion shaft teeth tighter into the worn grear; but you have to have the worn gear centered. Then lock the nut down to make sure the pinion shaft doesnt move up or down.
Jim_66SS is offline
