Auto or manual steering column? - Chevelle Tech
 3Likes
  • 1 Post By HKalin
  • 2 Post By RealRed70
post #1 of 8 (permalink) Old Sep 15th, 19, 7:08 PM Thread Starter
Dustin
Before I bought my 72 Chevelle it was converted to a 4 speed floor shift car. The steering column has a bar in the engine bay on the steering column that if rotated the vehicle cannot be turned off. I don't know if this is for an auto car or a manual car can anyone help me out what this is for?
I'll try to get a good picture tomorrow
1955 Ford Thunderbird
1969 Triumph TR6
1972 Chevelle - 396, 4 Speed
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
2012 Dodge Durango Citadel
Tegguy is offline
post #2 of 8 (permalink) Old Sep 15th, 19, 7:14 PM
autumngold
Re: Auto or manual steering column?
both,i usually chop it off and lock it in position.
1970 ls-5 numbers matching
marcrose is offline
post #3 of 8 (permalink) Old Sep 15th, 19, 7:29 PM
Hank
The bar or lever goes into the steering column right. There was a rod that ran from the transmission up to that lever on both automatics and manual cars. Normally if you put headers on the car you had to remove the rod. Once you remove it you can turn the collar all the way CCW so the car will start and the steering wheel will lock also. The only thing is if you removed that rod it also activated the reverse lights. You can put a switch on the transmission itself that gets activated by the reverse linkage to turn on the reverse lights.
NickeyChevelle likes this.
HKalin is online now
post #4 of 8 (permalink) Old Sep 18th, 19, 7:17 PM Thread Starter
Dustin
Sorry if I'm understanding correctly if I have headers I cannot use the factory feedback linkage in must have a switch mounted on the transmission am i correct?
1969 Triumph TR6
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
Tegguy is offline
post #5 of 8 (permalink) Old Sep 20th, 19, 7:02 PM
basically you have to find out if the headers will clear the backdrive linkage. All you can do is try to hook it up and see if it clears. jim
70 chevelle, SS clone 454 4 speed 3.31 12 bolt posi
71 camaro. (owned since 1978!) 454-th400 3.07 12 bolt
66 chevelle 350 4 speed 3.55 12 bolt and a newly added 142 wieand blower
Jim Mac is online now
post #6 of 8 (permalink) Old Sep 20th, 19, 7:28 PM
If what you call a bar is somewhat of a hook shape, then it is an automatic column. If it has a straight short tab on it that is about an inch and a quarter long then it is a 4 speed column. I would NOT cut this off.
caminonut and 71350SS like this.
RealRed70 is offline
post #7 of 8 (permalink) Old Sep 22nd, 19, 3:43 PM
Disabling the transmission back drive linkage will cause the steering wheel to lock under certain conditions while the car is in motion. It was designed as a safety system just like other safety systems on your car.
Toppless72 is offline
post #8 of 8 (permalink) Old Sep 22nd, 19, 6:50 PM
ON factory equipped 4 speed cars the shifter had to be put into reverse to lock the steering column and remove the key.That is what the linkage piece is that you have,the backdrive linkage is one of its names.
You can just leave it rotated all the way to the left it won't cause you any problems that way. Mines been that way the 19 years I've owned it.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
