Universal Joint - Chevelle Tech
  • 1 Post By surmin69
post #1 of 5 (permalink) Old Sep 15th, 19, 12:04 PM Thread Starter
kevin
Universal Joint
Need a recommendation for a rear Universal Joint. 68SS. This is the third one i have had to replace. The first one was orginal the second i dont know what make but failed within 500 miles, ( garage installed did not list make) Need a heavy duty, (squeak the tires once in a while) but mostly a driver. Made in the USA? grease fitting or not? Thanks.
etkevin1968 is offline
post #2 of 5 (permalink) Old Sep 15th, 19, 12:32 PM
Bart
re: Universal Joint
Dana Spicer
https://spicerparts.com/parts/drives...le_paid_search
Kirk's67SS likes this.
69SS Daytona yellow
L35, M-20, 3.73
"AC's 2 by 75...... you roll'em down & drive
"Time treats everybody like a fool"
surmin69 is online now
post #3 of 5 (permalink) Old Sep 15th, 19, 1:23 PM
Greg.
re: Universal Joint
I have 1350 Spicers in my Car's Driveshaft F & R
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #4 of 5 (permalink) Old Sep 16th, 19, 4:27 PM
Harold
Re: Universal Joint
why did the first one fail ...lack of grease or broken due to "abuse"? First failure could have damaged parts causing 2nd failure. Or a cheap product was installed and/or not greased. Spicer and Neapco make superior products , both greaseable and non- greaseable . Do a little research with your mechanic.
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #5 of 5 (permalink) Old Sep 21st, 19, 11:19 AM
Greg.
Re: Universal Joint
Kevin
you also should check your Pinion Angles to make sure they are not the reason you are breaking the U-Joints
as under strong launches if the Angles are off the Driveshaft can be pushed up into the Rear Tunnel Floor
and if the Driveshaft is too Long then it can cause the same in the Front by Bottoming out in the Trans
Born 283 / PG / A51
60' = 1.664
60' = 1.547
