4 wheel disc brake conversions - anybody do one? - Chevelle Tech
 2Likes
  • 1 Post By Nazarah
  • 1 Post By the heckler
post #1 of 12 (permalink) Old Sep 11th, 19, 11:41 AM Thread Starter
Hi I picked up a complete 4 wheel disc brake conversion kit for a 1969 Chevelle at a swap meet - - with NO instructions.
Anybody done one of these? Can you offer advice, etc on how to change the back spindles? What Brake fluid did you run?
*Also read somewhere that 454's don't put out enough brake pressure and you can add some kind of brake pressure booster??
Thanks!
Thunderbolt13 is offline
post #2 of 12 (permalink) Old Sep 11th, 19, 11:44 AM
Matt
Send a message via AIM to Nazarah
Re: 4 wheel disc brake conversions - anybody do one?
Which brand is the conversion kit? Usually you can find something online for instructions if none were included.
Years ago I did one from CPP. It was pretty straight forward. But I also had instructions!
Do you have a booster on the car now, or is it 100% manual breaks? If you do have a booster, unless you're dealing with some sort of performance built engine, I'd think you'll have enough vacuum to operate the booster fine.
Never stop learning!
Nazarah is offline
post #3 of 12 (permalink) Old Sep 11th, 19, 5:14 PM
Kevin
I bought mine from Baer and it had instructions but the swap is pretty straight forward. If you don't have a booster, I would add one. I have a pretty performance based engine and the vacuum is fine. Huge cams reduce vacuum and can cause challenges but in most cases you will be fine.
As far as the rears go, your remove the brakes and backing plate bolt on the adapter, put the rotor on and bolt up the caliper. In most cases you will have to remove the rear axles but that is easy as well. E-Brakes vary, some are internal (like a mini drum brake) and some just hook up to the stock cables.
As mentioned above, instructions should be available online.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #4 of 12 (permalink) Old Sep 11th, 19, 6:26 PM Thread Starter
Thanks All.
This is pretty much a China kit. And haven't been able to locate any instructions online.
I know I have to remove the rear axles to get the spindles on, and that kinda scares me.
If anyone has suggestions of DO's or DON'Ts on how to remove the rear axles...I'd sure like to hear. Thanks again!
post #5 of 12 (permalink) Old Sep 12th, 19, 12:09 AM
Ben
Id post pics of what you have. May be a fairly common design and someone could point you to instructions.
And your location.
No car yet; currently looking for 66-69 project/driver.
skreddy is offline
post #6 of 12 (permalink) Old Sep 12th, 19, 3:14 AM
There are no spindles in the back. do you mean caliper brackets? or what?
post #7 of 12 (permalink) Old Sep 12th, 19, 10:16 AM
Matt
Originally Posted by Thunderbolt13 View Post
Thanks All.
Removing the rear axles isn't all that bad. It was a first for me as well when I did it, it goes pretty smoothly.
Do's or Dont's are very much going to depend on your car and the kit. What I would say is do have a clean place to do this at. I did mine in an asphalt driveway in the dead of summer. It was......not a lot of fun. Do have at least two jack stands and a decent jack. Also, DO be ready to safely decompress the front springs if you need to change out that front spindle. That's the part that always makes me pucker a little.
Also, be sure the rears are aligned properly once you get them on there. Mine were a bit off and they rubbed all the time. I had to adjust the bracket back there a bit to make them work.
If you get stuck, post up here for some advice. And pictures are worth 1000 words sometimes.
Thunderbolt13 likes this.
Nazarah is offline
post #8 of 12 (permalink) Old Sep 12th, 19, 11:05 AM
kevin
look up right stuff detailing. that is where my kit came from. they have all kinds of instructions/videos online. if it has the cadillac style rears with emergency brake calipers - very "fun" getting it set up - not!. pretty easy swap though....
the heckler is offline
post #9 of 12 (permalink) Old Sep 12th, 19, 12:06 PM Thread Starter
"DO be ready to safely decompress the front springs if you need to change out that front spindle."
Oh mann, didn't know about that one either. Thanks for the heads up!
post #10 of 12 (permalink) Old Sep 18th, 19, 10:38 AM Thread Starter
Originally Posted by the heckler View Post
look up right stuff detailing. that is where my kit came from. they have all kinds of instructions/videos online....
Hey Mann - Thanks! Excellent info source!
https://www.getdiscbrakes.com/knowle...r-disc-install
https://youtu.be/PJpC0W6CP78
post #11 of 12 (permalink) Old Oct 2nd, 19, 4:10 PM
Bart
I 2nd this. I used the Right Stuff 4 wheel kit on my car and it was very very simple install. I did the whole thing in about 2 hours, front and rear. I am sure the instructions will be close enough to get you where you need to be with your kit.
Bart_Swisher is offline
post #12 of 12 (permalink) Old Oct 2nd, 19, 4:43 PM
kevin
the rear brakes on mine literally took me a year to get functioning properly. my culprit? - the rear rubber hose from the body to the line block on the differential was the original 1968 version and had collapsed on the inside. this was never mentioned as a to-check item in the instructions. $20 hose later they worked perfectly...consider this a heads up!
