Ceramic Brake Pads... - Chevelle Tech
 5Likes
post #1 of 16 (permalink) Old Sep 5th, 19, 9:47 PM Thread Starter
I am pretty sure that the 'ceramic' brake pads from parts houses are actually 'ceramic metallic'. These have only been on my car for about 2 months and they look like crap (they are the Duralast Max pads). I ordered a set of Performance Friction carbon metallic pads to replace them with (I ran the PFC pads for years when Autozone sold them with a lifetime warranty). Since I just had the rotors machined when I put the ceramics on, I just scuffed them up with some emery cloth. I am just going to do without the lifetime warranty from here on out. I would rather have good pads that don't crack, overheat, and fade.
ID:	602484   Click image for larger version
My Chevelle w/ open headers:
1971-Chevelle is offline
post #2 of 16 (permalink) Old Sep 5th, 19, 10:15 PM
Greg.
Re: Ceramic Brake Pads...
Brian that is so like the Times as nothing seems to last very long
Hope these PFC pads work for you
as the Front ones on my car have been changed just in Aug 30, 2017
and I check them every Spring to see if they need Replacing
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 16 (permalink) Old Sep 5th, 19, 11:03 PM
leo
I always use the Ultra Premium pads from NAPA, great pedal feel and lifetime guarantee as well! Yes, I have had to take them up on replacement pads for free!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #4 of 16 (permalink) Old Sep 5th, 19, 11:09 PM
jerry
Just put a set of those duralast pads on the Honda, never again. Don't last and they really wear on break-in letting you know everytime you brake with a sweet aroma.
cheveslakr is online now
post #5 of 16 (permalink) Old Sep 5th, 19, 11:14 PM Thread Starter
I'd like to know how you got them to replace the pads without them being defective, since their warranty does not cover wear. Same with O'Reilly.
post #6 of 16 (permalink) Old Sep 5th, 19, 11:48 PM
leo
I bring in my invoice and ask for replacement pads, pay for them and get a refund when I return the old pads, pretty simple for me. The old pads are worn out!!
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #7 of 16 (permalink) Old Sep 6th, 19, 5:03 AM
I use Evolution Powerstops on my Hellcat. Stop good, clean and last. I use them because the lack of brake dust. The Brembos were filthy.
LeoP likes this.
67-468 is offline
post #8 of 16 (permalink) Old Sep 6th, 19, 10:13 AM Thread Starter
But that's just it - the warranty does not cover wear - only manufacturer defects. They should not be replacing them because they are worn down. I would never get away with it.
post #9 of 16 (permalink) Old Sep 6th, 19, 5:00 PM
Alex
I was always told that Autozone would replace your pads as long as they had a certain amount of pad left on them.
1969 Chevelle SS --- 468 FTI Level 4 TH400 AFR 290cc's
1997 S10 SS ---LQ9/4l65e
Chevymec is offline
post #10 of 16 (permalink) Old Sep 6th, 19, 5:06 PM
mike
They are Lifetime warranty, I've done it hundreds of times, some with no receipt, either worn out or if not, making noise works.
LeoP likes this.
slowmo55ss is online now
post #11 of 16 (permalink) Old Sep 6th, 19, 5:08 PM Thread Starter
That is at Autozone and that is their warranty (they only carry their own brand of brake pads now). If you read the warranty from Wagner, Bendix, and many of the other major manufacturers, the warranties exclude wear. O'Reilly doesn't cover wear, either. So, I will just stick with the PFC pads - they are superior to pretty much any of the stuff that the major parts houses sell.
post #12 of 16 (permalink) Old Sep 6th, 19, 6:43 PM
Vince
Ive also had great luck using Powerstop gear from Rock Auto. Usually I like OEM pads but the Powerstops work good and are priced right.
67-468 likes this.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is offline
post #13 of 16 (permalink) Old Sep 6th, 19, 10:13 PM
leo
Unlimited lifetime warranty replaces worn out pads at NAPA when you purchase Ultra Premium pads!!
67-468 likes this.
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #14 of 16 (permalink) Old Sep 7th, 19, 8:01 AM
Never had any luck with ceramic pads... I like Porterfield pads and shoes..
hydro462 is offline
post #15 of 16 (permalink) Old Sep 7th, 19, 2:19 PM
autumngold
Ceramic pads are dust free but score the rotor up.semi metallic are usually noisey, more dust,organic used to be prefered for road use but can crack between the rivits.I think fred flintstone had the best ones.
hydro462 likes this.
1970 ls-5 numbers matching
marcrose is offline
