PSI range for air shocks on a 69 2dr post - Page 2 - Chevelle Tech
 10Likes
post #16 of 18 (permalink) Old Aug 12th, 19, 9:05 PM
Re: PSI range for air shocks on a 69 2dr post
Josh your car looks great!
If I were doing it, I would probably look under the car and check the air pressure required to lift it 1 inch at a time. When the shock is at the top of its travel, whatever air pressure is required to get it there would be all I ever used. Then I would be able to correlate air pressure to ride height. This is just my guess but I bet you will blow a line off before you damage the shock.
Good luck with it!
If a government spent $30bn to find better uses for carrots, there would be carrot appreciation societies, carrot conventions, 400 patents on carrot-based wing-nuts, tents, and textiles, and 4000 peer-reviewed references on worrying declines in carrot hue, nutrients, fertility and genetic diversity, not to mention gender inequality in dietary carrot content
Alan F is offline
post #17 of 18 (permalink) Old Aug 13th, 19, 2:40 PM
always fun when the shocks punch through into the trunk.
post #18 of 18 (permalink) Old Aug 16th, 19, 9:01 AM
Great pictures shared !!
SimonJones is offline
