Ride height with Moroso drag springs - Chevelle Tech
 5Likes
  • 1 Post By NickeyChevelle
  • 1 Post By mr 4 speed
  • 1 Post By Kirk's67SS
  • 1 Post By Floorguy
post #1 of 12 (permalink) Old Aug 5th, 19, 9:15 PM Thread Starter
Hello all,
I was wondering if you guys could give me some advice on my ride height. I have a 68 Chevelle. 496 stroker, iron heads, longtube headers, aluminum intake , power steering, standard alternator, aluminum radiator and fiberglass hood. I also have the 1/2" taller upper ball joints if they matter. Anyway it seems like my stance is a little too heigh in front
I have the Moroso drag springs in front 47190. 250lb rate. Bottom of the crossmember to the ground is 7"-8" ground to the opening fender is 28 1/4"
Seems slightly "gasser " like. What do you guys think?
Can you cut down the drag springs?
It's definitely settled, they've been on for a couple months now
"... the very powerful and the very stupid have one thing in common. They don't alter their view to fit the facts, they alter the facts to fit their view." Dr. Who, 1977
NW68SSBBC is offline
post #2 of 12 (permalink) Old Aug 5th, 19, 10:49 PM
Bruce
Re: Ride height with Moroso drag springs
Yes, you can cut down the front springs. You'll want to "sneak up" on them and cut maybe a quarter of a coil at a time (you can always cut more, but you can't put back what's been cut).
You shouldn't cut rear variable rate springs unless you know what you're doing.
BTW: I've heard that the drag spring make the car sit lower by 2 - 3 inches. Are you sure they're installed correctly?
Kirk's67SS likes this.
Our You Tube Vids:
NickeyChevelle is online now
post #3 of 12 (permalink) Old Aug 5th, 19, 10:58 PM
Vince
Originally Posted by NW68SSBBC View Post
Hello all,
i have similar springs and my car sits low...
what size front tires are you running///
my fender opening is only 24 7/8'' with 215-65r15 tires
my hookers scrape on most driveways and speedbumps
VinceS427bb is online now
post #4 of 12 (permalink) Old Aug 6th, 19, 5:35 PM Thread Starter
Thanks for the reply
The springs are in correctly. I specifically marked the orientation of the notch in the spring pocket so they would line up the spring so that should be spot on
post #5 of 12 (permalink) Old Aug 6th, 19, 5:40 PM Thread Starter
The tires are 215 70R 15 in front. The battery is also in the truck so that may account for there not being enough weight on the springs
Here is how it's sits
post #6 of 12 (permalink) Old Aug 6th, 19, 10:19 PM
Bruce
The springs "fit" around a "crown" at the top of the spring mounts. Whereas, it's unlikely that one could mess up both springs, it's the tops that could be an issue.
Nice Ride! But it seems really weird that the front end would sit up that high with the trick springs and no spacers.
This is what I'd expect to see:
VinceS427bb likes this.
Our You Tube Vids:
post #7 of 12 (permalink) Old Aug 6th, 19, 11:42 PM
Vince
that yeller car sits very similar to my junk..
post #8 of 12 (permalink) Old Aug 7th, 19, 6:45 AM Thread Starter
I agree. That's why I asked. I love the weight transfer though!
JOE
post #9 of 12 (permalink) Old Aug 7th, 19, 7:43 AM
One of my fellow S/A racers has the Moroso trick springs on his 1970 SS454, it sits a little bit taller than stock IMHO but they work well.
ID:	599924   Click image for larger version
BB68 likes this.
mr 4 speed is offline
post #10 of 12 (permalink) Old Aug 7th, 19, 9:17 AM
Greg.
Put the Moroso Trick Springs # 47195 250 lbs in my 67 Chevelle and the Frontend dropped 3 inches
had to add a 1" Spacer under the Bottom of the spring so the Tire would not rub on the Fender Lip when turning
Tire up front is a 205 / 70 / 15 on a 15x7 Wheel with a 4" BS and Battery in Trunk
BEFORE with Stock Springs
AFTER with the Moroso Trick Springs and 1" Spacer
There has to be something not Right
NickeyChevelle likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #11 of 12 (permalink) Old Aug 7th, 19, 5:57 PM Thread Starter
Thanks for all the replies!
Everything thing is right from an assembly standpoint. I will just have to cut them down a little to suit me. I have the OTC spring tool which makes assembly a snap. I'll probably mess with it later this fall. This week the motor is coming out to fix a leaky rear pan gasket, rear main, or seal the rear main cap area. Or all of the above! Fricken sick of oil pan leaks. But that's another subject!
post #12 of 12 (permalink) Old Aug 26th, 19, 12:19 PM
As far as ride height goes. Mine is 23 to the fender lip in the front and 23/12inthe rear. That’s with a 29-14.50 15 rear tire...Attachment 601584
Floorguy is offline
