Hydroboost??? - Chevelle Tech
 7Likes
post #1 of 17 (permalink) Old Aug 4th, 19, 9:10 PM Thread Starter
Hydroboost???
Does anyone have the measurements of the spring that goes between the hydroboost unit and the master cylinder? I made an output rod and have order 2 springs and they are too big to fit in the unit. I measured where the spring goes and I think a 1.25" dia. and 2.75" length. is what would fit in mine.
suprdave1 is offline
post #2 of 17 (permalink) Old Aug 4th, 19, 10:40 PM
Re: Hydroboost???
Mine doesn't have a spring in it. Pulled the unit from an 03 C30, modified the mount plate and pedal rod to fit in my 72 Chevelle.
Pete 67 and LeoP like this.
63 Nova wagon
Philip is offline
post #3 of 17 (permalink) Old Aug 4th, 19, 11:01 PM
Re: Hydroboost???
The factory GM unit I used didn't have a spring either. It was complete with the master cylinder when I got it.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #4 of 17 (permalink) Old Aug 5th, 19, 6:38 AM Thread Starter
Re: Hydroboost???
Ok guys thanks. Thatís been my biggest holdup 👍👍
post #5 of 17 (permalink) Old Aug 5th, 19, 7:12 AM
Re: Hydroboost???
Just to add, I'm using a junkyard hydroboost out of an 03 Tahoe in my 64, no spring, no issues.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #6 of 17 (permalink) Old Aug 5th, 19, 10:33 AM Thread Starter
Re: Hydroboost???
Can someone photos of your setup including hose routing?
[email protected]
Thanks in advance
post #7 of 17 (permalink) Old Aug 5th, 19, 11:23 AM
Re: Hydroboost???
I'd used the firewall bracket from the tahoe, pressed out the studs, filled the holes, then drilled 4 new holes for the chevelle setup (and welded in a mount for my clutch setup). I also had to enlarge the hole in the firewall for the neck of the hydroboost to pass through. Email sent.
OLDED likes this.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #8 of 17 (permalink) Old Aug 5th, 19, 9:24 PM
Jason
I used a comp cams valve check spring for a LS motor (4758-1) it was a perfect fit. Custom built output rod.
I used the CPP firewall bracket. Routing goes from pump to hydroboost inlet. Then hydroboost outlet to steering gear inlet. I used 2 return lines didn’t want to tee them.
So from steering gear outlet to reservoir.
Hydroboost return line to reservoir.
I used AN fittings. Bulk head style for the extra return line just drilled a hole and tightened it down.
Also used Gm 2771004 Hydro-boost for the star retainer clip.
OLDED likes this.
Jasons 69 Chevelle is offline
post #9 of 17 (permalink) Old Aug 5th, 19, 9:38 PM
Jason
Photos
ID:	599862   Click image for larger version
ID:	599864   Click image for larger version
ID:	599866   Click image for larger version
post #10 of 17 (permalink) Old Sep 12th, 19, 8:45 PM
Did you buy the CPP firewall bracket individually or as a kit? I've been looking for a bracket and have come up empty so far. Any help is appreciated.
mvaughn is offline
post #11 of 17 (permalink) Old Sep 12th, 19, 10:18 PM
Re: Hydroboost???
No bracket is needed, just modify the stock hydroboost bracket. It is simple to do and free.
OLDED likes this.
63 Nova wagon
Philip is offline
post #12 of 17 (permalink) Old Sep 12th, 19, 10:58 PM
leo
Re: Hydroboost???
Philip, you should do a write-up on your fitment and plumbing of your unit and make it a sticky on this Forum!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #13 of 17 (permalink) Old Sep 13th, 19, 10:07 PM
Jason
It’s $69 from CPP you will have to call them they sell it individually but I don’t have the part number handy.
post #14 of 17 (permalink) Old Sep 17th, 19, 10:35 PM
Re: Hydroboost???
Itís $69 from CPP you will have to call them they sell it individually but I donít have the part number handy.
Is the only mounting option upside-down?
BlueJeep is offline
post #15 of 17 (permalink) Old Sep 18th, 19, 5:19 PM
Re: Hydroboost???
If you orient the Hydra-Boost unit so the pressure canister is on the engine side - you can use stock pressure hoses for a mid 80's Olds Delta 88 diesel application. These hoses are a perfect fit and cost less than $30.00 each at auto parts outlets anywhere. I like stock parts availability whenever possible in case of a failure.
LeoP likes this.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
