Wheel hop issues, looking to learn... - Page 3 - Chevelle Tech
 35Likes
post #31 of 51 (permalink) Old Jul 31st, 19, 2:50 PM Thread Starter
Shawn
Re: Wheel hop issues, looking to learn...
Originally Posted by 71350SS View Post
This is a quote from your first post in this thread
: With the car leveled on stands, I've got -4* at the tailshaft and balancer (checked both to be sure) and I set the pinion to -1*, so total is -5*, right? Is that too much?
I may be wrong but I think you should double check it with it at ride height to see if it changes too much one way or the other.
It was on stands with the suspension loaded. The trick was getting it level front to back with the rake I have going haha.
71350SS likes this.
Mel0Yel068
Mel0Yel068 is offline
post #32 of 51 (permalink) Old Jul 31st, 19, 2:59 PM
My car sits pretty high and I have zero wheel hop. I boxed my lower rear control arms. My understanding was always that wheel hop was mainly caused by flexing of the rear lower control arms. They bend under acceleration and then the hop is caused by the controls arms straightening themselves out. Boxing them in eliminates the flexing.
'72, 385 sbc, Voodoo roller, 219/227; .515/,530 lift; AFR 180cc Eliminators, RPM Air-Gap, 770 Avenger, TH350 trans, 12 bolt 3.42's, Eaton Posi, TCI 2000 stall, Pypes 2 1/2" X-pipe system w/Race Pro's
Vehicle weight: 3390 lbs
Autoengineer_ is offline
post #33 of 51 (permalink) Old Jul 31st, 19, 3:06 PM Thread Starter
Shawn
I thought the same thing, but there's lots of suggestions on the internet. That's why I always come back here because you guys have the best advice for Chevelles. I've replaced all the rear stock suspension - new uppers/lowers, springs, shocks, bushings. The uppers are adjustable and the lowers are square channel boxed. Both have pivot joints at the front. These parts made little to no impact on the wheel hop. Next step is no-hops I guess. They're easy enough to install. If this doesn't work I guess I just don't do burnouts, because I'm not interested in lowering the stance - at this point :-)
Mel0Yel068
post #34 of 51 (permalink) Old Jul 31st, 19, 6:17 PM
Greg.
Shawn
wheel hoping will break things/parts pretty quickly
so be careful
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #35 of 51 (permalink) Old Jul 31st, 19, 11:06 PM
jackie
I have Lakewood No Hop Bars in conjunction with Hotchkis controls arms. I get zero wheel hop when, as you say, I “light em up”.
jackie schmidt is offline
post #36 of 51 (permalink) Old Jul 31st, 19, 11:20 PM
With the rear raised the upper control arms are pointing up towards the front. When you apply torque it pulls the car down & the rear up just the opposite of what you want. Good recipe for hop. The no hops should do the job.
mr 4 speed likes this.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #37 of 51 (permalink) Old Aug 1st, 19, 6:20 PM
p40
butch
Originally Posted by Rich-L79 View Post
And make the car ride like a chuckwagon.
oh and they ride like a caddy? these ol muscle cars never rode that good cant have your cake and eat it to
p40 is offline
post #38 of 51 (permalink) Old Aug 1st, 19, 9:53 PM
Your car looks great, I installed Competition Engineering Coil Spring Traction Bars part# C2111 on my 70 chevelle with factory ride height! That’ll fix you right up. Enjoy that chevelle.
HairBandDan is offline
post #39 of 51 (permalink) Old Aug 2nd, 19, 12:59 AM
My 65 Chevelle sits a little tall cos when I built it I wanted to do it Old School!! Everyone was telling me to drop the front end a few inches but I refused to listen to them. I guess I did it right cos If I can get the video to play you can see for yourself. I think an hour trying to get it to post is long enough it keeps telling me invalid file!!
tsvehe is offline
post #40 of 51 (permalink) Old Aug 2nd, 19, 10:25 AM
Air bags slightly inflated will work for you.
buzzbomb2 is offline
post #41 of 51 (permalink) Old Aug 2nd, 19, 11:05 AM
Jon N.
Try again after you have more than ten posts.
Jon N.
dyno jonn is offline
post #42 of 51 (permalink) Old Aug 2nd, 19, 11:10 AM Thread Starter
Shawn
I ordered the TA Performance no-hops yesterday, hope to have them installed by next weekend. I'll let you know how I made out.
lucifershammer likes this.
Mel0Yel068
post #43 of 51 (permalink) Old Aug 2nd, 19, 11:58 AM
Glen
Here's my no-hop bars. I took the rear end out to install, much easier. I also installed poly bushings and UMI adjustable uppers. Replaced the brake lines while I was there. The original lower arms are boxed and new rubber bushings installed. 1" UMI rear sway bar. But, I still have a little wheel hop, I guess the next thing is UMI lowers with poly bushings. mine sits up a little higher than original also.
Name:	chevelle rear end.jpg
ID:	599596   Click image for larger version
ID:	599598   Click image for larger version
Name:	chevell rear end 2.jpg
1968 Chevelle
468 Big Block
Muncie M20 4 Speed
12 Bolt Posi 3.31:1 Gears
glend123 is offline
post #44 of 51 (permalink) Old Aug 2nd, 19, 12:15 PM Thread Starter
Shawn
Looks great! The rear came out the first time last fall to do the gear swap, no idea why I didn't just do all this then. So it came out a second time this year to replace all the suspension components, u-joint, bushings, etc. I HOPING I can just drop the rear low enough to remove the upper bushings/install the no-hops w/o taking it out a third time. A lift would be nice, but what fun is it w/o a challenge. I am getting more efficient each time though ;-)
Mel0Yel068
post #45 of 51 (permalink) Old Aug 7th, 19, 5:45 PM Thread Starter
Shawn
Hey guys, small update. Got the no-hops from TA Performance Monday night. Hoping to tear into it tonight, we'll see how far I get. Wish me luck!
Mel0Yel068
