Master Cylinder won't pump fluid - Chevelle Tech
 5Likes
post #1 of 22 (permalink) Old Jul 26th, 19, 6:35 PM Thread Starter
Beth
I'm trying to bleed my brakes; just installed LS1 brakes on all 4 corners of a 67 Chevelle.
I have the bleeder screw at the passenger side rear cracked open and connected to a reservoir of fluid with a clear hose. All other bleeder screws are closed and the system seems tight - no leaks.
As I pump the brake pedal, the master cylinder reservoir does not change - no fluid is going down the lines.
I've disconnected the line going to the rear of the car and blew 30 psi air through it.
I checked the rod between the booster and the master cylinder- it seems to have plenty of stroke ; about 1-1/2".
Do I need a hand vacuum pump to get the fluid moving to the rear brakes ?
nashville beth is offline
post #2 of 22 (permalink) Old Jul 26th, 19, 6:41 PM
Jason
Open all the bleeders then once it starts dripping close them and do one at a time.
Jasons 69 Chevelle is offline
post #3 of 22 (permalink) Old Jul 26th, 19, 6:47 PM Thread Starter
Beth
Re: Master Cylinder won't pump fluid
Thanks, I'll go try that; I need to see some fluid start to move ! LOL
post #4 of 22 (permalink) Old Jul 26th, 19, 6:52 PM
If your using the original distribution block the valve may be off center restricting fluid movement. There is a bleeding tool to aid in bleeding your brakes.
https://www.ebay.com/itm/Combination...0AAMXQVT9TBk9g
Good Luck
PCB67SS is offline
post #5 of 22 (permalink) Old Jul 26th, 19, 7:09 PM Thread Starter
Beth
Master Power Brakes Combination Valve Video - YouTube
Good Luck
Thanks but I removed the distribution block because of the rear disc brakes.
I cracked open all 4 bleeders and the MC still won't pump.
Wondering if I need to pull a vacuum on one line at a time to help the fluid move down the line.
I'm using Dot 5 silicone fluid and I think it's a thicker viscosity.
post #6 of 22 (permalink) Old Jul 26th, 19, 7:38 PM
Jason
Just open them up when I first did mine it took about 4 hours to start dripping no need to pump. When you pump with the bleeders open it will suck air back in threw the bleeders.
post #7 of 22 (permalink) Old Jul 26th, 19, 8:47 PM Thread Starter
Beth
Thanks. Just got back from Harbor Freight with a Mity-Vac hand pump.
post #8 of 22 (permalink) Old Jul 26th, 19, 9:33 PM
Yeah, sometimes that's needed to get things started.
I can HIGHLY recommend speed bleeders from Dorman, 12706 for the LS F-body calipers. I had a stubborn bleeding job like this and they worked great-they allow you to quickly pump the brake pedal.
If this is the original disc/drum master, it may have a residual pressure valve in it for the rear section which will hold like 5psi in the line and cause the rear pads to drag.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #9 of 22 (permalink) Old Jul 26th, 19, 10:45 PM Thread Starter
Beth
I hope the master doesn't have anything "built-in" to hold pressure. It came as part of a "booster -master cylinder- proportioning valve" combo from the Right Stuff.
It had a disc-drum proportioning valve that I swapped out for a disc/disc PV.
So I wouldn't think the MC would also have a residual pressure valve ?
I disconnected the 1/4" rear brake line before the rear axle flex hose and started pulling vacuum there. It wouldn't hold a vacuum but I did start getting a trickle of brake fluid through the line.
I have to go out of town so I'm admitting defeat right now.
I will check out those speed bleeders. Thanks
post #10 of 22 (permalink) Old Jul 26th, 19, 10:50 PM
I'm sure it's correct then.
How may I help you?
1999 Trans Am-500hp
post #11 of 22 (permalink) Old Jul 27th, 19, 2:19 PM
was that the one from from Wrong Stuff or Online Boob?
PCB67SS, SSJohn and Kopfjaeger like this.
post #12 of 22 (permalink) Old Jul 28th, 19, 8:38 PM
My guess is the rubber line at the rear end is swollen shut. I had a similar problem and I started at the master cylinder and had someone pump the brake while I cracked the next fitting in line. If it has pressure coming out of the MC, go to the next fitting in line and so on. When I got to the hard line to rubber line junction near the rear, I had fluid/pressure. When I went to the junction where the rubber line connects to the T fitting on the rear end, no pressure. So the rubber line was the culprit. $15 at NAPA and the brakes work better than ever.
I often forget the car is 50 years old. If you never replaced that line before, I recommend it to anyone even if you don't have symptoms yet.
400 SBC, 9:1, AFR 195s, TH400, Coan converter, 3.50
ProCharger D1SC, Super Sniper EFI conversion 2019
1.30 60', [email protected] on pump gas
Greg Owens is offline
post #13 of 22 (permalink) Old Jul 28th, 19, 9:45 PM Thread Starter
Beth
It's from the "Wrong Stuff"
I replaced all the lines except for the 1/4" steel running from front to back. Blew air thru it in both directions.
I'll be back thursday to try again and will report back then.
post #14 of 22 (permalink) Old Jul 28th, 19, 11:00 PM
Lyle
I don't see any mention of bench bleeding the master cylinder.
427L88 likes this.
lkmarsh is offline
post #15 of 22 (permalink) Old Jul 29th, 19, 10:38 AM
Yes to these!
USAF Retired (1968-1988)
David Bates is offline
