Is this a 67 tilt column ? - Chevelle Tech
 3Likes
post #1 of 20 (permalink) Old Jul 9th, 19, 11:36 PM Thread Starter
Beth
I have a tilt column I bought a few years ago.
On the electrical connector it says "Delco-Remy D-8-67"
Is this for a Chevelle ? I hope so LOL
ID:	597870   Click image for larger version
nashville beth is offline
post #2 of 20 (permalink) Old Jul 11th, 19, 1:39 PM
Re: Is this a 67 tilt column ?
No......the mount plate for a 67 will have 3 of the aluminum block mount locations, not 2 as shown in your picture. Cant help with what it might fit, but its not a 67.
PCB67SS is offline
post #3 of 20 (permalink) Old Jul 11th, 19, 1:45 PM
Bill Wente
Don't know what it is but not even close to '67 Chevelle.
A few '67s and a '66
67since67 is offline
post #4 of 20 (permalink) Old Jul 11th, 19, 2:39 PM
In the future here's some info that will help identify columns that are NOT for early Chevlles or any 67 Chevelles.
First thing is the steering shaft. 64-66 Chevelles have a one piece shaft that runs from the steering wheel to the steering box. 67s have a two piece shaft (that looks like a one piece shaft) that is collapse-able but also runs from the steering wheel to the steering box. So if you see a column that uses a bolt on steering shaft, right off the bat, you know it can't be for an early Chevelle.
Next, '67 Chevelles have a mast jacket (the tube which is painted & covers the shaft) which has a steel mesh section in the tube which is designed to crush in a collision. Originals have a plastic sleeve covering the mesh section, but a lot of times the sleeve is missing. So again, if the entire length of the mast jacket tube is solid, it CANNOT be for a '67 Chevelle.
Hope this helps.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #5 of 20 (permalink) Old Jul 11th, 19, 11:27 PM Thread Starter
Beth
Hope this helps.
I think most of us are lost unless you include a picture explaining what to look for.
My column is dated 1967 , so what GM cars is it for ? I wonder if there is any reference for these steering columns?
Thanks for the input
post #6 of 20 (permalink) Old Jul 12th, 19, 1:08 AM
There may be something of assistance here:
Jim Shea?s Steering Papers
David
davewho1 is offline
post #7 of 20 (permalink) Old Jul 12th, 19, 7:24 AM
I'll make a wild guess and say pickup. That is 67 wiring on it right? Didn't they switch to the rounded connector after that?
Pioneer4x4 is offline
post #8 of 20 (permalink) Old Jul 12th, 19, 1:04 PM
https://rover.ebay.com/rover/0/0/0?m...2F323792457152
Take a look at this ebay auction. This column has the correct bowl where the column would meet the dash. Also, notice the "collapsible cage" towards the end of the column.
I think you have a BOP column from pre-67.
Columns are 1967 only, Chevelle only, so very unique. That's why a rebuilt original will bring $750+.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #9 of 20 (permalink) Old Jul 14th, 19, 12:00 PM
Originally Posted by Pioneer4x4 View Post
...That is 67 wiring on it right? Didn't they switch to the rounded connector after that?
No, 1967 (Model Year Chevelle) and earlier Chevelles used a "half-moon" shaped wiring connector for the column. Not sure when, but the straight connectors were for newer applications...
TC #1366
Sold
Sold
1966_L78 is offline
post #10 of 20 (permalink) Old Jul 14th, 19, 12:14 PM
Trying different browser for first time. = Edge
post #11 of 20 (permalink) Old Jul 14th, 19, 12:52 PM
OK, so that is a 68 or newer wiring in that column. I knew I bought a straight to curved adapter for my 70s column switch wiring to my 67 harness. But I forgot which way it was.
post #12 of 20 (permalink) Old Jul 14th, 19, 1:37 PM
That looks an aftermarket GM style column.
dell72 is offline
post #13 of 20 (permalink) Old Jul 14th, 19, 5:30 PM
Jon N.
GM/Saginaw probably built about half of the steering columns and steering gear boxes used in other than GM branded vehicles. Add that to the mix.
LeoP likes this.
dyno jonn is offline
post #14 of 20 (permalink) Old Jul 16th, 19, 3:12 PM Thread Starter
Beth
The non-tilt column currently in my 67 is not a 67; maybe a 66? It has the correct curved connector but doesn't appear to have the "meshed" collapsible part of the column.
I'll be looking for a replacement but have too many things needing $$ spent on right now
Thanks for the great info
This is on ebay right now; looks like the one in my car.
It's a non-tilt floor shift. Doesn't look like it's collapsible ?
https://www.ebay.com/itm/67-1967-CHE...sAAOSw2opdG0Ws
Name:	67 column.jpg
post #15 of 20 (permalink) Old Jul 16th, 19, 3:30 PM
Jon N.
Beth, that column on ebay shows it has plastic pins in the lower shaft. I'm saying it's collapsible.
