proforged pitman arm p/n info needed - Chevelle Tech
post #1 of 2 (permalink) Old Jun 10th, 19, 11:35 PM Thread Starter
'64 Chevelle... converting from manual to P.S. so I need a new/different pitman arm. There are two versions of P.S. pitman arms. Rockauto sells four different Proforged pitman arms for early Chevelles. Problem is they are only described according to the different diameters they have in their ends. Without having any of the other parts already I can't tell for sure which pitman I need. I plan to use the Proforged #11610009 tie rod assembly when they are available from Rockauto again. I also plan to use a Turn One T12BASE steering box which is supposed to be a Saginaw 700 equivalent. Considering what I've described can anyone tell me with reasonable certainty which Proforged pitman arm p/n I'm going to need?
traveler is offline
post #2 of 2 (permalink) Old Jun 12th, 19, 11:53 AM Thread Starter
Re: proforged pitman arm p/n info needed
Proforged was really on the ball e-mailing me that for my application I needed their 10310040 pitman arm. Answered my question long after quitting time but same day I asked it. His answer did not specifically reference the particular steering gear I want to use but hopefully that was part of his thinking. Rockauto is currently out of both the Proforged 11610009 tie rod assembly and the 10310040 pitman arm.
traveler is offline
