'66 IDIDIT install without cutting stock column? - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old Jun 13th, 19, 4:57 PM
Lew
Re: '66 IDIDIT install without cutting stock column?
Originally Posted by GregSnook View Post
It would seem like it's the same as using a straight DD bar, just need the rag joint in the bottom, cut to length, and coupler at top?
Yes that is correct.
Lew540 is online now
post #17 of 20 (permalink) Old Jun 13th, 19, 6:42 PM
Troy
Similar, but not the same. If you use a telescoping steering shaft, it will be 1" DD at the steering column and 3/4" DD at the rag joint.
66 CHEVELLE
senna is offline
post #18 of 20 (permalink) Old Jun 14th, 19, 2:16 PM
Cory
Step 1. Remove 3 mounting screws of the turn signal switch mechanism
Step 2. Slide the retainer sleeve from the column jacket
Step 3. Pull the turn signal switch and cup away from the column. The wiring harness half moon plug will slide through the shifter collar.
Reassemble in reverse order. You'll discover that the cup must be aligned with the tabs on the jacket to secure the assembly.
Name:	Steering Column BBC - 002 annotated.jpg
dream66 is online now
post #19 of 20 (permalink) Old Jun 14th, 19, 3:05 PM Thread Starter
I should have asked, any wear items I should replace at this point, or spots to add some grease/other lubricant?
GregSnook is offline
post #20 of 20 (permalink) Old Jun 14th, 19, 3:19 PM
Cory
Grease the upper bearing and lower bearing. Nothing else to do.
