69 Chevelle Steering Column Support - Chevelle Tech
 6Likes
  • 3 Post By 68-13427
  • 1 Post By NickeyChevelle
  • 1 Post By ZZ69chevelle
  • 1 Post By RealRed70
post #1 of 7 (permalink) Old Jun 7th, 19, 5:57 PM Thread Starter
Frame off resto ragtop. The column brackets are bolted to the support brace below length of dash. That support brace the full length of dash moves slightly and thus so does steering column. Looks like there should be supports that attach that support brace to firewall. Non are present. What are they called? Where would I find them?
post #2 of 7 (permalink) Old Jun 7th, 19, 7:14 PM
Terry
Re: ‘69 Chevelle Steering Column Support
Buy an Assembly Instruction Manual for your car. It has all the information you need to show the parts you need, and where they are installed. Terry
68-13427 is offline
post #3 of 7 (permalink) Old Jun 7th, 19, 7:38 PM
Bruce
Re: 69 Chevelle Steering Column Support
A picture is worth a thousand words...
I believe the location you're referring to is marked in red on the below thumbnail. There should be a pair of bolts that are welded to the cowl and those bolts hold this section of metal dash with a couple of nuts.
Like Terry said: Get the FAIM. https://www.americanclassic.com/1969...20group%20%231
Our You Tube Vids:
NickeyChevelle is offline
post #4 of 7 (permalink) Old Jul 2nd, 19, 6:44 PM Thread Starter
Ok I took advice on assembly manual. I need part 3927660 and 3927662. No search results. Where can I get these parts?
post #5 of 7 (permalink) Old Jul 2nd, 19, 8:28 PM
Bruce
Try Arizona Chevys AzChevs "No Rust,Just Dust"
Joe is a member here.
68-13427 likes this.
Our You Tube Vids:
post #6 of 7 (permalink) Old Jul 2nd, 19, 8:33 PM
You can buy a piece of round stock and make these if you can't find them. Get the shape and length with a piece of coat hanger for a template, and then make up a pair from the round stock. That size isn't too hard to hammer the ends flat after heating with a map torch.
ZZ69chevelle is offline
post #7 of 7 (permalink) Old Jul 2nd, 19, 8:33 PM
Most people will not know what those parts are unless you post a picture of them. That is if you can come up with a picture. Someone here may have what you need, but will need a picture to know what it is you need.
RealRed70 is offline
