Brakes get Hot,Drag,then Lock Up? - Chevelle Tech
 45Likes
post #1 of 54 (permalink) Old May 31st, 19, 2:10 PM Thread Starter
My 69 Chevelle has a Right Stuff Disc Brake Conversion kit . After driving for few minutes the brakes start to drag, then you can smell them and if you stop they will lock up . After about ten minutes they cool down and you can drive again . Any ideas ? This is pretty frustrating . Thanks!
BRN2RUN is offline
post #2 of 54 (permalink) Old May 31st, 19, 2:35 PM
Harold
Re: Brakes get Hot,Drag,then Lock Up?
when the brakes start to lock up , pop a bleeder to see if pressure is present. If so , master cylinder push rod may be too long
OLDED, LeoP, BRN2RUN and 2 others like this.
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #3 of 54 (permalink) Old May 31st, 19, 3:42 PM
kevin
mine do this on the rear disc only in my '68. it too is a right stuff kit. following this post...
BRN2RUN likes this.
the heckler is offline
post #4 of 54 (permalink) Old May 31st, 19, 6:20 PM Thread Starter
Thank you for the response ! So when I get back home I should open a bleeder and see if it squirts out?
BRN2RUN is offline
post #5 of 54 (permalink) Old May 31st, 19, 6:47 PM
Ken K.
BRN2RN. Agree with Harold on push rod maybe too long. If you loosen the bolts on the master cylinder and it jumps forward the rod is most likely the culprit. had to take .090 off mine to get the front brakes to release all the way.
SKIS69SS is offline
post #6 of 54 (permalink) Old May 31st, 19, 6:52 PM Thread Starter
Thank You !
BRN2RUN is offline
post #7 of 54 (permalink) Old Jun 1st, 19, 2:16 AM
What they said about the pushrod. The plunger in the M/C needs to be able to get ALL the back to rest position. If it doesn't a tiny little relief port is covered up and pressure builds. This is a very common issue these days with all the aftermarket being used.
post #8 of 54 (permalink) Old Jun 1st, 19, 7:21 AM Thread Starter
Thank You !
BRN2RUN is offline
post #9 of 54 (permalink) Old Jun 23rd, 19, 6:47 PM Thread Starter
Well I adjusted the push rod and it didn't make a difference . Even after separating the the master cylinder and booster TWO front brakes remain locked . I even tried putting two small washers between the Booster and MC, no difference. Any ideas? Remember it's both front brakes that lock! After a cool down they release.
BRN2RUN is offline
post #10 of 54 (permalink) Old Jun 23rd, 19, 7:59 PM
Roger
Where is your proportioning valve located? On the MC or on the frame in the original location?
Do you have headers?
If the proportioning valve is on the frame and you have headers, the heat from the headers may be heating up the P-valve, which means the fluid is getting hot, which means the brakes will lock up. Then release when the fluid cools down.
It happened to me after adding headers to my Elky. I had to relocate the P-valve to the MC.
BRN2RUN likes this.
1972 El Camino SS (sold)
1981 Camaro Z28
2005 Silverado 3500 LS
2013 Sierra 1500 SLT
DrPepper is online now
post #11 of 54 (permalink) Old Jun 23rd, 19, 9:42 PM
Levon
Is the piston in the master fully retracting? Also if you bench bled the master and over stroked it, the seals can invert and prevent the piston from actuating properly.
BRN2RUN likes this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is online now
post #12 of 54 (permalink) Old Jun 25th, 19, 6:54 PM Thread Starter
I was thinking along those lines , but the PV is located by the MC !
BRN2RUN is offline
post #13 of 54 (permalink) Old Jun 25th, 19, 7:00 PM Thread Starter
How can I tell if the piston in the MC is fully retracting? When I got home and jacked the front of the car up, you couldn't turn the wheels by hand. I separated the MC from the booster and still the wheels where locked . It wasn't till they cooled down that I could turn the wheels!
BRN2RUN is offline
post #14 of 54 (permalink) Old Jun 25th, 19, 7:12 PM
Levon
2 ways.
1) with the master cylinder pulled away from the booster, is the piston fully moved to the rear of the master closest to the booster?
2) with someone watching the master with its lid off and someone gently operating the brake pedal you should be able to see a small "geyser" erupt from the bottom of the master each time the brake is pushed and released. That is fluid entering and leaving the piston port of the master. It's a small hole at the bottom of each reservoir.
BRN2RUN likes this.
Levon Hovagimian
Team Chevelle #279
post #15 of 54 (permalink) Old Jun 25th, 19, 7:17 PM Thread Starter
Thank You!
BRN2RUN is offline
