Brakes get Hot,Drag,then Lock Up? - Page 4 - Chevelle Tech
 46Likes
post #46 of 54 (permalink) Old Jun 29th, 19, 5:09 PM Thread Starter
Re: Brakes get Hot,Drag,then Lock Up?
Originally Posted by paul bell View Post
Was this the original master cylinder that was on the car or did Right Stuff furnish it?
If original, was this a four drum brake car?
https://www.chevelles.com/forums/11102130-post23.html
It was a complete package from Right Stuff !
BRN2RUN is offline
post #47 of 54 (permalink) Old Jun 29th, 19, 5:17 PM
OK. Lots of good advise here but ultimately Right Stuff should stand behind their product when there's an issue.
BRN2RUN and lucifershammer like this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #48 of 54 (permalink) Old Jun 29th, 19, 5:20 PM
Levon
How long ago? Your picture of the master off of the booster looks like it has leaked at one time.
I would be following up with Right Stuff.
BRN2RUN likes this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #49 of 54 (permalink) Old Jun 29th, 19, 5:28 PM Thread Starter
I would be following u with Right Stuff.
It's a few years old but hardly any miles ! I was surprised to see the inside look like that, the car hasn't seen weather since the conversion.
I've contacted Right Stuff !
paul bell and DwadeCham like this.
BRN2RUN is offline
post #50 of 54 (permalink) Old Jul 2nd, 19, 11:57 AM
Keep us posted. I have had this problem in the past. A local shop thought there was just trash in the lines. Now I am thinking something larger is going on.
BRN2RUN likes this.
DwadeCham is offline
post #51 of 54 (permalink) Old Jul 2nd, 19, 8:14 PM Thread Starter
I will for sure , a big thank you for everyone's help!
DwadeCham likes this.
BRN2RUN is offline
post #52 of 54 (permalink) Old Jul 8th, 19, 8:17 PM Thread Starter
Ok I said that I would continue to keep you posted ! By now I thought I would have good news...nope! I think Right Stuff is as frustrated as I am.
Last thing I did was syphon the brake fluid reservoir and I was shocked to see the bottom of it loaded with crud ! The Kit was brand new and the car really never left the garage !
Can I just flush the system or God forbid do I need to replace everything? Frustrated!!!
BRN2RUN is offline
post #53 of 54 (permalink) Old Jul 9th, 19, 12:31 AM
Levon
You can "reverse flush" the system by pumping fluid in at the wheels and forcing it to the master.
I would just pull the master and the delay valve and empty/flush those to start with.
Then flush the whole system with new, out of the can fluid.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #54 of 54 (permalink) Old Aug 8th, 19, 8:05 PM Thread Starter
With all the help and advice I received here on this issue I had to let everyone know how I made out.
I flushed the entire system and installed a new master cylinder supplied by Right Stuff !
BINGO!!!!! I never figured out why the original one didn't work but the new one did the trick.
A shout out to Right Stuff who continued to work with me.
Thanks again everybody!
blm, lucifershammer and DwadeCham like this.
BRN2RUN is offline
