C5 based uprights - Chevelle Tech
  • 1 Post By Jasons 69 Chevelle
post #1 of 4 (permalink) Old May 31st, 19, 1:45 PM Thread Starter
Jason
C5 based uprights
Just finished up installing a updated suspension. SPC uppers, +.500 Howe upper ball joints from SC&C.
Uprights are CCP c5’s
Hubs are c7 skf trackers. C5 calipers and rotors are from rock auto raybestos. Still need to setup a alignment. I used a SPC camber castor gauge to eyeball it. +5* castor and -.75* camber.
I measured the ccp uprights and they are 8.25 inches from mounting surface. That’s why I went with the +.5 ball joints. The tie rod ball joints are nearly inline with the lower control are joints with the stock steering arms. Total cost was around $1000
Mainly the skf c7 hubs. Before and after photos attached.
ID:	594820   Click image for larger version
Jasons 69 Chevelle is offline
post #2 of 4 (permalink) Old May 31st, 19, 10:51 PM
Mark
Re: C5 based uprights
Did this change your track width any and if so how much from old to new setup vs oe track width?
modern malibu is online now
post #3 of 4 (permalink) Old Jun 1st, 19, 12:05 AM
Allen
Good question, I was wondering the same thing.
Blown1932 is offline
post #4 of 4 (permalink) Old Jun 1st, 19, 3:38 PM Thread Starter
Jason
70 1/4 inches is what I’m reading from the outside edges of the tires
