Wilwood Proportioning Valve Install Help - Chevelle Tech
  • 1 Post By NorCal-SS
post #1 of 6 (permalink) Old May 26th, 19, 9:09 PM Thread Starter
I’d like to know what others have done in this situation. I’ve installed a Hydratech booster and Wilwood master cylinder in my ’65 El Camino. The issue is that the Wilwood proportioning valve and hard lines will not fit between the master cylinder and the driver’s side inner fender. The solution seems to be to “reshape” the inner fender so it clears, i.e. beat it in…not very cool looking. (The blue tape in the photo shows where the fender work needs to happen.) Also, switching the proportioning valve to the passenger’s side of the master cylinder won’t work either. It hits the coils covers on the LS3.
Baer makes a good looking master cylinder with the proportioning valve mounted UNDER it. That would work great. But I’m trying to avoid paying for another master cylinder and valve.
Has anyone else run into this and what the heck did you do. Your input is greatly appreciated!
Name:	IMG_6313 Edit for Chevelle Forum.jpg
rmc65elco is offline
post #2 of 6 (permalink) Old May 26th, 19, 9:54 PM
Rich
Re: Wilwood Proportioning Valve Install Help
Here's mine on my 65 wagon. But then, I don't have a hydroboost. You'll just have to get creative with the lines if you don't want to cut the inner fender. You could also put the valve in the line farther down the line, perhaps under the car. It's not like you'll be adjusting it every other day once you get it set where you want it.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is online now
post #3 of 6 (permalink) Old May 26th, 19, 10:17 PM Thread Starter
Good point about adjusting it only once. Creative plumbing may be the best answer!
post #4 of 6 (permalink) Old Jun 6th, 19, 3:36 PM
J
Make a new bracket to position the prop valve closer to the master cylinder. You will then need to make new hard lines to connect the 2 pieces. You will likely need to include loops in the hard lines as the prop valve and mc will be close to each other. I’ve had to do this with other builds. I have a hydraulic shop near by that can do this no problem. Might be a better option if you’d rather not DIY.
rmc65elco likes this.
NorCal-SS is offline
post #5 of 6 (permalink) Old Jun 6th, 19, 3:40 PM
"Wild Bill"
I installed an adjustable prop valve in the rear feed brakeline mid frame.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is online now
post #6 of 6 (permalink) Old Jun 6th, 19, 4:54 PM Thread Starter
NorCal-SS: Thanks for the suggestion. I'll have a look and talk to my local shop. I'd rather spend my money making this work, than buying another one!
'67-'70 Disc Hold Off Valve von Brakes, Suspension & Steering 19 May 26th, 16 6:14 PM
Valve Spring Install Height Help sidehiller_5 Engine 42 May 12th, 16 4:48 PM
Not enough room for proportioning valve. dougs70ss Brakes, Suspension & Steering 6 May 27th, 15 9:16 PM
Need help Bad Proportioning Valve HKalin Brakes, Suspension & Steering 6 May 25th, 15 6:52 PM
no proportioning valve hard pedal watevadunno Brakes, Suspension & Steering 12 Apr 19th, 15 5:48 PM
