Popping noise after new parts - Chevelle Tech
  • 1 Post By LevonH
post #1 of 9 (permalink) Old May 25th, 19, 7:49 PM Thread Starter
Hey guys i have a 73 chevelle and I’m having a little bit of an annoying issue after rebuilding the front suspension, I replaced all the tie rod ends, adjusting sleeves, centerlink, idler arm, sway bar links, control all arm bushings, all ball joints and greased everything than got a full alignment done. Now when I’m turning slowly especially into my driveway and around parking lots i can hear a audible popping sound and can sometimes feel it in the steering wheel or slowly going over bumps i can also hear the popping. Other than that the car drives nice and straight and smooth as a Cadillac down the highway. Any help is greatly appreciated.
@1973chevelle is offline
post #2 of 9 (permalink) Old May 25th, 19, 8:03 PM
Bart
Re: Popping noise after new parts
I would start with someone in the car turning the wheel lock to lock, while you are at the front end looking and listening. is there anything hitting something.
What brand of replacement parts did you use? Did you set the torque values on the upper and lower control arm bushing with the full weight of the car sitting on the ground?
69SS Daytona yellow
L35, M-20, 3.73
"AC's 2 by 75...... you roll'em down & drive
"Time treats everybody like a fool"
surmin69 is offline
post #3 of 9 (permalink) Old May 25th, 19, 8:05 PM Thread Starter
I used moog for everything and tightened the upper and lower control arms without the weight on the car, could my problem be there?
post #4 of 9 (permalink) Old May 25th, 19, 8:17 PM
Justin
Idk if it is your problem but you definitely want them snug, then lower the car on the ground for the final torque of the control arms.
JF74chevelle is offline
post #5 of 9 (permalink) Old May 25th, 19, 8:20 PM Thread Starter
Should I raise the front of the car, loosen them, lower the car than re torque them? What difference does it make doing it that way?
post #6 of 9 (permalink) Old May 25th, 19, 8:30 PM
Bart
That is how I would do it. hopefully that will solve the problem. let us know.
69SS Daytona yellow
L35, M-20, 3.73
surmin69 is offline
post #7 of 9 (permalink) Old May 25th, 19, 9:14 PM
Levon
. YES!!
This will take the preload out of the rubbers. After loosening everything, bounce the car a few times and let it come to rest. Then torque all bolts to spec.
LeoP likes this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #8 of 9 (permalink) Old May 25th, 19, 9:26 PM Thread Starter
Could i have damaged anything from driving the car this way? I’ev driven it about 500 miles since doing everything.
post #9 of 9 (permalink) Old May 25th, 19, 9:39 PM
Yes, you could of ripped the rubber from the sleeve but I doubt you did this.. Just straighten them out and save your pennies for a new set of SC&C Stage Three arms with the Delrin bushings and Howe .9 tall ball joints. They are a dream come true compared to the factory stuff...
hydro462 is offline
RockAuto.com Discount Code for Parts & More - Expires June 26, 2018 RockAuto RockAuto 0 Mar 26th, 18 12:00 PM
Terrible noise in reverse Autoengineer_ Transmission & Driveline 7 Sep 30th, 17 12:55 AM
Morel Hydraulic Roller Lifters....Noise... cstraub Performance 20 Mar 6th, 14 9:06 AM
69 Malibu WIW? NickeyChevelle What's it worth? 9 Apr 8th, 13 1:00 AM
NOS parts and GM part numbers earnhardtgw3 Restoration Corner 16 Mar 30th, 13 8:21 AM
