want to convert from drum to disc - Chevelle Tech
 6Likes
  • 1 Post By modern malibu
  • 5 Post By Chicagopd50
post #1 of 13 (permalink) Old May 12th, 19, 6:45 PM Thread Starter
ok i h ave a question about converting front brakes to disc from old drums.. i have a 4 speed car and currently i have no power brakes/booster.
my question is there something special i need from brake pedal rod being too long or short for the new booster set up and also will this interfere with my clutch pedal? thanks for the info in advance.
someone is always faster !
Chicagopd50 is offline
post #2 of 13 (permalink) Old May 12th, 19, 9:16 PM
Mark
Re: want to convert from drum to disc
The new booster push rod will mount to the pedal assembly with the same pin used to attach your existing manual rod. You will also need to use the lower hole in the pedal assembly for the correct pedal ratio. The conversion should not affect the clutch pedal at all.
modern malibu is offline
post #3 of 13 (permalink) Old May 13th, 19, 12:30 AM Thread Starter
Ok thanks, I also noticed that my windshield wiper motor is very close to my master cylinder as is sits now without the booster.. is there a specific size I need to clear the wiper motor?
post #4 of 13 (permalink) Old May 13th, 19, 3:41 PM
Mark
It looks as though you have some tall valve covers from the pic, so I would suggest a dual 9 inch booster. You should not have any interference with the wiper motor.
Chicagopd50 likes this.
post #5 of 13 (permalink) Old May 15th, 19, 6:47 PM Thread Starter
Thanks for the info.. much appreciated
post #6 of 13 (permalink) Old May 17th, 19, 6:54 PM
Daron
Hey Chicago. Post some pictures of your car back on the introduction thread. We all want to see your ride bud.
1967 Chevelle SS
427 BBC
Straub Hydraulic Roller
Muncie 4 Speed
Daron Craig is offline
post #7 of 13 (permalink) Old Jun 16th, 19, 9:41 PM Thread Starter
heres my ride... true 138 code ss.. new red interior.
ID:	595956   Click image for larger version
post #8 of 13 (permalink) Old Jun 17th, 19, 3:45 PM
Harold
food for thought....add disc without a power booster, increase rear drums to 11' , and car will stop good , no fitment problems and much cleaner look underhood .
Use a D50 style caliper but with a D153 pad, it has about 20%more lining than a D50
New paint -near complete
66 SS 396. now 427
86 Buick Grand National
And a bunch of other junk.
driveshaft-texas is offline
post #9 of 13 (permalink) Old Jun 18th, 19, 7:34 PM
Pat
Do you have drop spindles in the front and what wheel and tire size.
55pat is offline
post #10 of 13 (permalink) Old Jun 18th, 19, 8:53 PM
great looking car, black with red gut. No baloney, just good looking car.
post #11 of 13 (permalink) Old Jun 19th, 19, 2:54 PM
Harold
stock spindles and 15"x8 American wheels
stock spindles have to be modified a little but not hard or critical spec task
66 SS 396. now 427
post #12 of 13 (permalink) Old Jun 19th, 19, 3:08 PM
blm
Just thought I would mention the following in case someone else needs the info. They make tall valve covers that l ook just the the stock chrome valve covers that allow the use of a stock brake booster. They are called "cheaters". I have them on my 69 with roller set up and original booster.
blm is offline
post #13 of 13 (permalink) Old Jun 21st, 19, 3:27 PM
I have 15 x 8 Cragars in front no power booster installed Wilwood Dynalite 4 piston and Wilwood non power booster master and have been happy ever since, also was able to use the existing drum spindle no modifications
Bradco is online now
Looking for a drum to disc kit that doesn't push the front rims out David Welsh Brakes, Suspension & Steering 7 May 26th, 17 3:37 PM
Problems with "Right Stuff" rear drum to disc system crankitup Brakes, Suspension & Steering 14 Sep 22nd, 16 10:35 PM
'68 Drum Spindle Mods to '69 Disc Brackets von Brakes, Suspension & Steering 1 Nov 16th, 13 5:25 AM
72 front disc rear drum want to convert rear to disc Rick34 Brakes, Suspension & Steering 3 Oct 30th, 13 10:17 AM
NEW Wilwood Less expensive kit SALE MCB Sponsors 13 May 9th, 13 12:18 PM
