Sway bar time.. Thinking Hellwig.. - Chevelle Tech
 16Likes
  • 1 Post By SSJohn
  • 3 Post By Dansk
  • 1 Post By Gtogeoff
  • 1 Post By hydro462
  • 1 Post By Chevy67
  • 1 Post By SSJohn
  • 4 Post By blm
  • 2 Post By SSJohn
  • 1 Post By Slick71ss
  • 1 Post By Jasons 69 Chevelle
post #1 of 13 (permalink) Old May 11th, 19, 9:06 AM Thread Starter
My 69 el Camino has SC&C stage 3 kit, .9 &.5 tall ball joints and Delrin bushings, a Lee 14:1 box up front with adjustable Spohn Delrin control arms in the rear..
I have the stock sway bar now with no rear bar. It handles okay but I feel I am leaving a lot at the table. I was thinking about starting with a new Hellwig front bar. Unless I am mistaking, I believe they have three for my 69 A body.
#5703 1-5/16"
#5709 1-1/8"
#5706 1-1/4"
My car is all street so ride quality is important to me, I drive very steep curvy roads here in Western Pa.
I am open to different brands.
What would be my best choice?
Thank you..
hydro462 is offline
post #2 of 13 (permalink) Old May 11th, 19, 1:00 PM
Re: Sway bar time.. Thinking Hellwig..
Maybe a call to Mark Savitske is in order. The front and rear bar need to be matched for best performance. On that note, actually all the suspension components need to work together as a system. I have a copy of his book, how to make your muscle car handle. I used the info from the book to set my car up and have no complaints.
hydro462 likes this.
SSJohn is offline
post #3 of 13 (permalink) Old May 11th, 19, 10:11 PM
I bought a Hellwig rear and a UMI front and can say that the UMI fit and finish were far above the Hellwig.
hydro462, Kirk's67SS and paul bell like this.
Dansk is offline
post #4 of 13 (permalink) Old May 12th, 19, 5:11 AM
Geoff
I had Hellwig front & rear & no complaints at all. The FR bar was 1.25" & hollow. It definitely firmed up the ride, you could notice it when one fr wheel hit a bump.
I forget the size of the rear bar, I think it was 1" or close to it. Well made, & sturdy clamps that went over the axle tubes. Self locking nuts came with it. Three adjustments for stiffness, plus the length of the link arms was adjustable.
Gtogeoff is offline
post #5 of 13 (permalink) Old May 12th, 19, 8:39 AM Thread Starter
I can't get a hold of him, he must be busy..
He helped me set my car up with his Stage III and it is perfect! Then he custom ordered my steering box from Lee by asking me what physical condition I am in and how big I am. Do I have issues with my hands fumbling over the steering wheel and what diameter the steering wheel is..
In any case the steering box turned out to be a dream come true! I never knew power steering could be like this!! Its a 800 Series Lee 14:1 with a 30 pound valving (what ever that means).. He said the 14:1 is just barely 1 point slower then the 12.7:1 and would be better for a street only car because they aren't overly sensitive on the highway. My experience shows they have a slightly longer center crown then the 12.7 so there not so sensitive going down the road at hi speed ( I think? Please correct me if I'm wrong).. He was 100% on the mark or should I say Marc lol.. Sorry for the long text but this box is amazing!!
SSJohn likes this.
hydro462 is offline
post #6 of 13 (permalink) Old May 12th, 19, 9:34 AM
Kevin
Mark helped me set up my suspension. He recommended a 1 5/16" bar for the front and a 1" bar for the rear. I have a Hellwig out back and a Hotchkis in the front and they work well together. Ride is great unless you hit a pothole with one wheel, then you know that the bars are there and work.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #7 of 13 (permalink) Old May 12th, 19, 3:50 PM
I also have a lee box at 12.x:1, great box, I love it. Well worth the money. It is a little quick at high speed, anything under 90 is sweet. Over 90 make you pay attention.
SSJohn is offline
post #8 of 13 (permalink) Old May 12th, 19, 4:15 PM
blm
I also have a UMI front and rear. The rear is the type that does not attach to the rear control arms. Mark states in his book the attaching a sway bar to the control arms binds up the rear suspension. Couldn't see going through the trouble of installing rear control arms with Jonny joints just to bind them up. The chassis mount bars are pricey though. Mine is UMI part #4045.
blm is offline
post #9 of 13 (permalink) Old May 12th, 19, 4:31 PM
All my suspension parts are umi w/Viking 2 ways, fronts are coil overs. We have the same rear bar, and yeah, it was expensive. Great bar, launches nice and straight.
hydro462 and Kirk's67SS like this.
SSJohn is offline
post #10 of 13 (permalink) Old May 12th, 19, 6:27 PM
Phil
Hellwig 55868 is a nice rear bar. It attaches to the axle and frame, not control arms.
If 55703 will fit, I'd go with that front bar. It is hollow vs their others that are solid. I'd be concerned about it clearing everything though, being 1 5/16".
71 Chevelle SS
zz502 (Straub Cam, RPM Airgap, ProSystems Carb, MSD, etc.)
Rossler TH400
Built 12 bolt 4:11
Pics
Video
Slick71ss is offline
post #11 of 13 (permalink) Old May 16th, 19, 4:23 PM
Jason
Just installed the Hellwig 1 5/16 front bar. Actually just got back from the first ride with it. Had a 1 inch bar on the front so it was firmer.
It clears everything and fit perfectly. I used Spohn spherical end links and have the delrin/poly ridetech swaybar mounts are on the way. The rear has the Spohn pro Turing adjustable bar. Also a nice bar. The rear lower control arms are UMI with the roto joints highly recommend them also.
-SS454- likes this.
Jasons 69 Chevelle is offline
post #12 of 13 (permalink) Old Today, 9:43 AM
Geoff
Have UMI bar front, Hellwig bar in rear, really like it. Also have the SC&C front end components...
Geoff1200 is offline
post #13 of 13 (permalink) Old Today, 12:23 PM
Greg.
I do believe you are talking about a Anti Roll Bar
Not a Sway Bar
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
Now 468/Th400 2,500 stall/ S60 3.70 Gs
Prev Best on M/T S/R #6641 street Tires/Dress 2016/10/9
60' = 1.720
1/8 = 7.747 et / 89 mph
1/4 = 12.112 et / 112 mph
NEW Best on M/T ET S/S #3454 street Tires/Dress 2018/05/20
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
Kirk's67SS is online now
Going BLACK - UMI Performance Revises Sway Bar Brackets UMI Performance Sponsors 0 Mar 25th, 19 10:40 AM
Sway Bar Bushings Bind tmcmillan5 Brakes, Suspension & Steering 2 Jan 1st, 16 7:14 PM
Sway bar hits steering box TXCR13 Brakes, Suspension & Steering 15 Oct 27th, 15 10:15 PM
Installing a sway bar on a non sway bar 67 el camino JKK Brakes, Suspension & Steering 2 Jul 4th, 15 2:14 PM
Hellwig Drag Bar for 68-72 GM A-Body now Available [email protected] Sponsors 14 Feb 6th, 13 10:33 AM
