Sway bar time.. Thinking Hellwig.. - Page 2 - Chevelle Tech
 25Likes
post #16 of 27 (permalink) Old May 20th, 19, 10:11 AM
Jules
Re: Sway bar time.. Thinking Hellwig..
Originally Posted by SSJohn View Post
Maybe a call to Mark Savitske is in order. The front and rear bar need to be matched for best performance. On that note, actually all the suspension components need to work together as a system. I have a copy of his book, how to make your muscle car handle. I used the info from the book to set my car up and have no complaints.
SS John, did you work from his revised edition or previous?
mymalibubu72 is offline
post #17 of 27 (permalink) Old May 20th, 19, 1:24 PM
Pat
UMI front and rear on my 70 ( mounted to UMI lower control arms) took all the body roll out of the car and I have zero issues with it binding the rear suspension.
Kirk's67SS likes this.
Pats70ss is offline
post #18 of 27 (permalink) Old May 20th, 19, 2:56 PM
Greg.
Originally Posted by Gtogeoff View Post
Kirks67SS,
Anti roll/Drag bar? Which drag bar is that? And your criticising me for just using the word bar? Any reason you didn't criticise many other posters for just using the word 'bar'? Or the OP who opened the thread with 'Sway bar' & not 'Anti Sway bar'.
Geoff as has been pointed out to you by many TCs there is a difference in how each one is Mounted/Installed
And how they help with or hinder the Car's Suspension
The one ( Anti Roll/Drag Bar ) you described in your Post # 4 is a lot different in how it is Mounted/Installed to our Cars
than an OEM Type Sway Bar is Mounted/Installed in our Cars
I asked the OP which one he was talking about in my Post # 13
and I did not criticise you for using the word "Bar" that I know of !
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #19 of 27 (permalink) Old May 20th, 19, 3:22 PM
Iíll have to look when I get home, will post a pic of the cover.
SSJohn is offline
post #20 of 27 (permalink) Old May 20th, 19, 9:56 PM
Greg.
Same here to Pat on my 67 plus I have the Rear Upper Adjustable Control Arms
which help Centre the Rearend and set the Pinion Angle correctly
Pats70ss likes this.
Born 283 / PG / A51
60' = 1.664
60' = 1.561
post #21 of 27 (permalink) Old May 21st, 19, 12:17 AM
Phil
I think some of the confusion is caused by Hellwig. They themselves call their "anti-roll" style bar a sway bar. The Hellwig version is a nice piece for street cars or cars that just see the track occasionally. It isn't as stout as some of the others like UMI, Spohn, etc., so it still has some give, but has the benefits of tying the axle to the frame instead of the control arms.
This link has good photos of this particular bar... https://static.summitracing.com/glob.../hel-55864.pdf
71 Chevelle SS
zz502 (Straub Cam, RPM Airgap, ProSystems Carb, MSD, etc.)
Rossler TH400
Built 12 bolt 4:11
Slick71ss is offline
post #22 of 27 (permalink) Old May 21st, 19, 3:02 PM
No mention of revision.
ID:	594124   Click image for larger version
SSJohn is offline
post #23 of 27 (permalink) Old May 21st, 19, 3:23 PM
Not just Hellwig calls these "sway bars". Below are all the same style as the Hellwig - mounted to axle and frame.
UMI - "GM A-BODY 1Ē TUBULAR REAR SWAY BAR, CHASSIS MOUNTED"
1964-1972 GM A-Body 1? Tubular Rear Sway Bar, Chassis Mounted [4047-XXX] - $429.99 : UMI Performance, Inc.
Spohn - "Pro-Touring Adjustable Rear Sway Bar"
https://www.spohn.net/shop/1968-1972...GM-A-Body.html
1972 Chevelle, 454, 2004r, 3.08
lucifershammer is offline
post #24 of 27 (permalink) Old May 21st, 19, 3:49 PM
Pat
I have the adjustable uppers as well Greg.
Pats70ss is offline
post #25 of 27 (permalink) Old May 21st, 19, 6:38 PM Thread Starter
I think I'll get a softer bar but use heavy end links..
hydro462 is offline
post #26 of 27 (permalink) Old May 22nd, 19, 8:40 AM Thread Starter
I'm going with the Detroit Speed bar. I always wanted to have all DSE parts and this will be a start. .
I'm using DSE 031402..
Anybody have any input on DSE?
Thank you..
hydro462 is offline
post #27 of 27 (permalink) Old Jun 8th, 19, 5:23 PM
Jules
Thanks SS John !
Best regards
Jules
SSJohn likes this.
Going BLACK - UMI Performance Revises Sway Bar Brackets UMI Performance Sponsors 0 Mar 25th, 19 10:40 AM
Sway Bar Bushings Bind tmcmillan5 Brakes, Suspension & Steering 2 Jan 1st, 16 7:14 PM
Sway bar hits steering box TXCR13 Brakes, Suspension & Steering 15 Oct 27th, 15 10:15 PM
Installing a sway bar on a non sway bar 67 el camino JKK Brakes, Suspension & Steering 2 Jul 4th, 15 2:14 PM
Hellwig Drag Bar for 68-72 GM A-Body now Available [email protected] Sponsors 14 Feb 6th, 13 10:33 AM
