Best way to bleed brakes - Chevelle Tech
 13Likes
post #1 of 76 (permalink) Old Apr 23rd, 19, 6:23 PM Thread Starter
Dennis
What is the best way to bleed brakes? I have a 66 with a Wilwood tandem master cylinder (no booster) and 4 wheel discs. There is also a proportion valve that is adjustable, all from Wilwood.
I bled the master before putting it on and have bled the system with a buddy working the pedal like 5 times and I just can’t get pedal.
I’m 99.9% sure I have no air/fluid leaks and I’m 99.9% sure I got the master cylinder completely bled.
I don’t have a “bleeder” but if if it’s worth it, I’ll buy one. Is a vacuum one better than a pressure type?
What do you guys do?
67_LS1 is offline
post #2 of 76 (permalink) Old Apr 23rd, 19, 7:11 PM
Bart
Re: Best way to bleed brakes
I have this. works great for me.
69SS Daytona yellow
L35, M-20, 3.73
"AC's 2 by 75...... you roll'em down & drive
"Time treats everybody like a fool"
surmin69 is offline
post #3 of 76 (permalink) Old Apr 23rd, 19, 8:11 PM
Rich
Five times? Nowhere near enough. You gotta keep bleeding.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #4 of 76 (permalink) Old Apr 23rd, 19, 9:02 PM
KEITH
You have to make sure the bleeder is at the top. Sometimes you need to take one loose to get the air to go towards the bleeder.
X-77keith is offline
post #5 of 76 (permalink) Old Apr 23rd, 19, 9:22 PM
Originally Posted by surmin69 View Post
Just bought one & used it to flush the fluid on my truck. Worked great.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #6 of 76 (permalink) Old Apr 23rd, 19, 9:47 PM
I’ve bled lines using every method and have settled on the good old gravity method. Takes a bit longer but no drama and I’ve never had to do it over.
pizzi-man, hydro462 and p40 like this.
any4xx is offline
post #7 of 76 (permalink) Old Apr 23rd, 19, 10:01 PM
Times two on the gravity bleed. do it on old and new autos. Don't take long at all especially if you forget to keep an eye on it
edspdog is offline
post #8 of 76 (permalink) Old Apr 23rd, 19, 10:01 PM
blm
When you are bleeding the rears are you getting any fluid out? Might want to give the gravity method a try.
Last year I replaced every component in nm my brake system except the pedal and the proportioning valve. I was having trouble getting the rears to bleed. Maybe something in this thread will help.
https://www.chevelles.com/forums/16-...ont-bleed.html
blm is offline
post #9 of 76 (permalink) Old Apr 24th, 19, 4:40 AM Thread Starter
Dennis
I’m getting fluid and more fluid until I think there is no more air and I still have a soft peddle.
Explain the “gravity method”.
67_LS1 is offline
post #10 of 76 (permalink) Old Apr 24th, 19, 7:57 AM
blm
Gravity method is just opening all four bleeders and just let gravity take over. Usually the fronts wll start to spew fluid first and once they do you can close them off and allow.the rears to start to produce fluid. If you do this I would recommend that you put a tube on the bleeders and route each tube to some type of container as if not the brake fluid will drip everywhere. This method can take anywhere from an hour to overnight. Also make sure the bowls in the master cylinder are not allowed to run dry or it defeats the purpose.
blm is offline
post #11 of 76 (permalink) Old Apr 24th, 19, 9:21 AM
Glenn
You should start with the bleeder furthest from the master cylinder.
Do one bleeder at a time working towards the master cylinder.
Usually left rear, right rear, left front, right front,
Get the right size hose (clear is best, but black works (you can see the air bubbles in the clear hose.))
Get a small jar with a cap on it and punch two holes in the top.
Put the hose through one of the hoses.
Put enough brake fluid in the jar to cover the bottom.
Push the hose down into the fluid in the bottom of the jar.
With the jar still connected set it on the ground under the bleeder screw you are working on.
At this point you can proceed with either the gravity method (one bleeder at a time), or the pump and hold method.
I use the pump method.
Now very important. Do not let the master cylinder go dry! At all times there should be at least a 1/2 inch of fluid in the master. Let it go dry in the process and you have to start over.
Pump and hold method, you need two people. The pump and hold method, the brake pedal is pressed while one bleed screw at a time is opened, allowing air to escape. The bleed screw must be closed before releasing the pedal, or a one-way valve must be fitted.
Place the end of you hose below the level of the brake fluid in the jar. You will see the air bubbles raise to the surface of the fluid in the jar. Most of the "draw back" into the tube will be fluid as the end of the hose is below the level of the brake fluid in the jar.
This is very frustrating work and chevelles are tough to bleed for some reason.
Here is a pretty good You Tube on Pump and Hold. They are demonstrating on the left front (incorrect, start on the left rear).
Glenn R. Lever
Rochester, New York 14617-2012
My Cars
Control arm Info
SS70ElCaminoOwner is offline
post #12 of 76 (permalink) Old Apr 24th, 19, 10:14 AM
I've noticed on many master cylinders, including from Wilwood, when you bench bleed it, you can see in the clear hose some air bubbles being sucked back in as you release the plunger. Before you release, pinch the hose with some pliers to prevent this.
Your rear Wilwood calipers may have two bleeders on the top that need to be bled. Do the outside one first then the inside one.
I have a pressure bleeder from Sealy, it works great, it uses air pressure from a tire. https://www.ebay.com/itm/Sealey-Tool...MAAOSwhTBa3z1X
I also have speed bleeders, they're check valves. Crack one, hose it to a container and slowly put the pedal to the floor a bunch of times.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #13 of 76 (permalink) Old Apr 24th, 19, 11:04 AM Thread Starter
Dennis
The gravity method sounds painfully slow. I’ve been using the pump and hold method with a second person even though I do have speed bleeders.
I have not let the master go dry but I’m just bewildered at how long it’s taking. I have pumped multiple large cans of brake fluid through the system. I wouldn’t think the volume of the MC, tubes, fitting and calipers would hold anywhere near what I’ve put through it.
67_LS1 is offline
post #14 of 76 (permalink) Old Apr 24th, 19, 11:24 AM
blm
Go back to link in.post #8. In that thread it talks about being able to see a geyser in each bowl/section of your master cylinder. If you don't see 2 geysers then something is amiss. Possibly just bench bleeding the master cyl again. That procedure takes two people. Also word of caution when inspecting for geysers hold the master lid or something else over the master as when these geysers shoot and you don't have something to catch them it will spray brake fluid all over the place. Also weak geysers is an indicator that everything is not hunky dorry.
blm is offline
post #15 of 76 (permalink) Old Apr 24th, 19, 11:36 AM Thread Starter
Dennis
I have not looked for geysers. I’ll try that this afternoon.
67_LS1 is offline
Rear Brakes Wont Bleed blm Brakes, Suspension & Steering 65 Jul 9th, 18 3:43 PM
Rear brakes won't bleed Daleo Brakes, Suspension & Steering 14 Oct 20th, 15 2:29 PM
Brakes won't bleed [email protected] Brakes, Suspension & Steering 8 Sep 22nd, 14 9:37 AM
'71 brakes won't bleed gobison Brakes, Suspension & Steering 4 Apr 12th, 14 11:22 PM
Brakes won't bleed cubcountry Brakes, Suspension & Steering 15 Feb 11th, 13 8:00 PM
