Ridetech full coilover kit. 67 Chevelle - Chevelle Tech
 16Likes
post #1 of 20 (permalink) Old Apr 23rd, 19, 3:57 PM Thread Starter
Hey all. I have been looking around on here and other forums. And I had a few questions about the ridetech full coilover kit. So I'll ask first does anyone have one on a 67? If so, how do you like it?
Binford is offline
post #2 of 20 (permalink) Old Aug 15th, 19, 7:05 AM Thread Starter
Re: Ridetech full coilover kit. 67 Chevelle
Bump
Bluesky10 likes this.
Binford is offline
post #3 of 20 (permalink) Old Aug 21st, 19, 11:09 AM
I have Ridetech Full Coilover kit installed on my 66, I think the kits are the same for a 66-67. I am VERY happy with it. Install was fairly easy (I installed a Wilwood front disk brake kit at the same time). The only issues I ran into was with the sway bar, I can go into it more if you decided to pull the trigger on the kit. Not really a big deal but I can save you some time.
I have had it installed for about 3 months and it feels like a completely different car. Not sure what type of a feel you are looking for but the next thing for me is to replace the steering box, it needs to be a bit quicker to make the car handle better. I bought my kit from Matts Classic Bowties (sponsor on this site), he did a great job of getting me the kit and the correct springs for my application.
I do have some pics of the install and how the car sits now (it is at the Ridetech suggested ride height) if you are interested.
Let me know if I can answer any other questions.
Mike P
66 Chevelle 300 Deluxe
MikeAP is offline
post #4 of 20 (permalink) Old Aug 21st, 19, 11:40 AM Thread Starter
Good to know. I'm pretty set that I'm going to go this route. As much as pictures would help I would suggest a different route. I'm very close to you. Maybe we could set up a meet and greet in a parking lot and I could check out the car/ suspension in person.
I'll pm you.
Binford is offline
post #5 of 20 (permalink) Old Aug 21st, 19, 2:30 PM
MikeAP and Binford,
This looks like a good starting point for me. I have a 67 project, and am leaning toward the Pro-Touring style, but maybe with a touch of Pro-Street.
My plan is to begin with the frame and build it up from there. My suspension is going to be my first part of the project.
I would really like to see some photos of your installs, and hear your input from the installations.
Thank you,
Name:	Frame Day 1.jpg
Binford likes this.
Bluesky10 is offline
post #6 of 20 (permalink) Old Aug 21st, 19, 3:41 PM
Originally Posted by Bluesky10 View Post
MikeAP and Binford,
Thank you,
Hi Steve, your frame looks REALLY good. Everything went very smooth during my install, I just ran into small issues with the sway bars (one was my fault).
I bought the kit last fall (Black Friday Deals). After the first of the year I saw that RideTech changed the rear sway bar that comes in the kit. So Matt took care of me and I was able to swap it out for the new version. The first issue was the new rear sway bar design would not work with my exhaust. I have a flowmaster 2.5" kit (exits just behind the rear wheel on the side). The new design hit the exhaust so I could not mount it to the frame. So Matt and RideTech worked with me and I was able to get the original style (bolts to the lower control arms) which worked with no issues. So if I would have kept the one I originally had I would not have had an issue.
The second issue was the front sway bar is suppose to mount to the factory front sway bar holes in the frame (you just have to drill and tap them to a bigger size). Mine was off by about 1/8" so I could not get the bolts in. Unfortunately where the holes lined up were right on the weld were the frame comes together. So I had to grind it down and drill new holes. Not a bug deal either but just wanted to let you know. I have detailed pics of the fix if you run into the same issue.
I have attached some pics.
ID:	601146   Click image for larger version
ID:	601148   Click image for larger version
ID:	601150   Click image for larger version
ID:	601172   Click image for larger version
ID:	601174   Click image for larger version
ID:	601176   Click image for larger version
ID:	601180   Click image for larger version
ID:	601182   Click image for larger version
ID:	601184   Click image for larger version
Mike P
MikeAP is offline
post #7 of 20 (permalink) Old Aug 21st, 19, 3:52 PM Thread Starter
That is one sexy car right there.
Binford is offline
post #8 of 20 (permalink) Old Aug 22nd, 19, 12:04 AM
Agreed Binford.
Mike,
Are you running the 10 or 12 bolt?
What brand and size wheels and tires on front and rear?
Please include off-sets for the wheels.
Did you have to modify the wells to have clearance?
What steering box are you using?
I will be running Wilwood disc on all 4 corners also.
Which part numbers did you go with?
Did the kit come with the coil overs, or a separate purchase?
Sorry so many questions, but your 66 has the stance I am looking for. Much easier to consider what works for someone else, so since you have been down that road, I would rather ask you.
Bluesky,
Binford likes this.
post #9 of 20 (permalink) Old Aug 22nd, 19, 11:48 AM Thread Starter
Looks like he's rocking usmag u111 in 18-8 and 18-9.5
Those wheels don't have a variable backspacing. So you get what you get.
I got the same wheels for my chevelle. They look good.
Binford is offline
post #10 of 20 (permalink) Old Aug 22nd, 19, 2:25 PM
Agreed Binford.
Mike,
Bluesky,
Thanks for the kind words guys. Steve I totally understand about seeing what works for other people. I bought this car last fall and spent most of the winter on this forum and others researching to find out what will fit or not. I hate to do things twice.
The first thing I did was replace wheels and tires. I went with US Mag Rambler (U111) wheels, rears are 18x9.5 fronts are 18x8. There is no option for backspace, they are both setup right in the middle (rear - 5.25 front - 4.5). I also went with Nitto NT 555 G2 tires, rear 275/40 front 245/45 (overall height is exactly the same). There is a pic on the US Mag website (in the Rambler wheels section) of a 66 Chevelle with the same size, I figured if they fit on that car they would fit on mine. There is no issue with anything rubbing, and I have not modified anything on the car for them to fit. Honestly, I think I can get a bit wider tire on the rear since there is plenty of room. I might do that when it is time to replace them.
I have the stock power steering box installed right now. My plan is to upgrade that at some point. I am leaning toward the Borgeson 12.7x:1 ratio box. Should make the steering feel more like a modern car.
I have the stock 10 bolt rear end in the car right now, I plan to upgrade that to a 9” this winter (looking at the Moser or Strange kits).
I wanted to car to handle like a modern car and have a low stance, but not too low. I found the RideTech compete coil over set (part # 11230201) looked like it would meet my needs. Everything was included in the kit, you can take a look at it on their website. The install was VERY easy, however I did run into 2 small issues with the sway bars. They were easily fixed, I can explain more later if you are interested. Since my steering links looked a bit “worn” I also replaced them with RideTech part # 11249570. The entire front suspension and steering (minus the PS box) is new on my car, so I should be all set for a while.
Since I am planning to replace the rear end this winter, I just replace my front brakes (kept the drum on the rears). The Wilwood website seems to be down this morning so I cant get you a part number but I can get it for you later if you are interested. I went with 6 piston 12.88” one-piece rotors. They bolted up without any issues. My car had the factory non power (single reservoir) master cylinder so I had to replace it to work with the Disc brakes. I went with the Wilwood master with attached prop valve. Works perfectly.
I think I answered all your questions, if you still have more I would be willing to chat on the phone if that helps. I will also say that I purchased everything (except wheels and tires) from Matt and Matts Classic Bowties. He is a sponsor on here, you can find him in the sponsor section (MCB). He was VERY helpful and gave me great prices on everything.
Mike P
MikeAP is offline
post #11 of 20 (permalink) Old Aug 23rd, 19, 10:07 AM
Thanks for the info. Strange offers bolt-ins now, but when I was in the market a couple of years ago for a rearend for my 77 Z, I looked at Strange and Moser, but at that time Strange did not offer the direct bolt-in's like today. Moser did, so I went with Moser. Great quality, and when they said direct bolt-in, that is what it was, with no issues at all. Here is a photo of mine installed.
post #12 of 20 (permalink) Old Aug 23rd, 19, 10:14 AM
I went with the 35 spline axels and with the street use the car will see, I went with a Wavetrac posi. Wavetrac® Differential - A torque biasing differential with a difference
Haven't looked lately, but Moser was the only distributer, and they have a lifetime warranty. Moser had tested them in their cars, and had not broken one yet.
post #13 of 20 (permalink) Old Aug 23rd, 19, 11:20 AM
Beth
I have a Strage S60 with the S-trac helical posi that is supposed to be stronger than the Eaton tru-trac.
It's as strong as a 9 inch and looks much better IMHO.
ID:	601328   Click image for larger version
ID:	601330   Click image for larger version
nashville beth is offline
post #14 of 20 (permalink) Old Aug 23rd, 19, 2:48 PM
Bluesky10 - I have been looking at both Strange and Moser. I had a bolt in Moser 9" in my 69 Chevelle years ago. You are right it was "Bolt In", really nice product. Looks like they both have "Bolt In" 9"s, 12 bolts and Dana 60s, with a ton of options. I live about 30 min from Strange so I could save on the shipping (but will have tax) so I am not sure what I will do yet. When I decided to make my 69 a drag car we replace the rear end with a Strange 9". We had an odd noise and we trailered the car to Strange and the Tech rode with me in the parking lot and knew exactly what the issue was. Brought them the center section back and they took care of if for free. So I am a bit partial to their customer service. However I do like the Moser packages also. My plan is to make a decision this winter so I am ready to go next spring.
nashville beth - that looks really nice. Not sure I know what a S60 is. Is that Stranges version of a Dana 60?
Mike P
MikeAP is offline
post #15 of 20 (permalink) Old Aug 23rd, 19, 8:28 PM
Greg.
I put a Strange S60 with the Tru-trac Helical / worm type Posi + Ford Housing Ends + Chrome Moly 1350 Yoke
+ LPW support cover + S/T Series 35 Spline Axles & ½” Studs
and they are stronger than any other Rearend based on my Research
Binford and Bluesky10 like this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
Extended Travel Coilover kit usnavyame70 Brakes, Suspension & Steering 16 Apr 12th, 17 7:22 PM
Chevelle 70-72 Flush Glass Kit FESLER Ready!!! Needs a Loaner Cronies74 Body Shop 15 Feb 8th, 17 11:18 PM
Rear Coilover conversion kit for 66 Chevelle tkmoto Transmission & Driveline 3 Apr 30th, 16 2:25 PM
Is there a carburetor kit available for a 1964 Chevelle 6 Cylinder? 64_Chevelle Engine 3 Mar 28th, 13 9:56 AM
Good or bad price for Sheet Metal Items joeperl Body Shop 4 Oct 26th, 12 3:52 PM
