1969 rear control arms - Chevelle Tech
  • 1 Post By SS70ElCaminoOwner
post #1 of 10 (permalink) Old Apr 13th, 19, 7:09 PM Thread Starter
I just picked up set boxed lowers and uppers for that came out of 1969 Chevrolet. I know I can use the losers with sway bar, but the uppers can they be used with the 69 12 bolt I just got too. Or will I have to user the uppers with modification from my 1967 as I read they are longer or shorter not sure which car currently has the 10 bolt rear
Bradco is offline
post #2 of 10 (permalink) Old Apr 13th, 19, 8:05 PM
Bruce
Re: 1969 rear control arms
The 1969 model year factory Rear Upper Control Arms for the 12 Bolt Rear End are slightly different from the Arms used with the '69's 10 Bolt. The 12 Bolt's Arms have a Reinforcement Tab on the Driver's Side Arm (the 10 Bolt versions do not have the reinforcement). The reinforcement was used because the Driver's Side Arms were cut down (radiused) to fit the 12 Bolt's upper ears.
The '68 through '72 Upper Control Arms were 10.25 inches. The '64 through '67 Arms were 12.75 inches.
Be aware that the width of the '69's 12 Bolt is different than the 67's...
Our You Tube Vids:
NickeyChevelle is online now
post #3 of 10 (permalink) Old Apr 13th, 19, 8:59 PM Thread Starter
So to install the 12 bolt in my 1967 do I use my 67 10 bolt upper control arms with drivers side modified or use the 69 10 bolt upper control arms with drivers side modified, also is their any benefit to having the uppers boxed?
Bradco is offline
post #4 of 10 (permalink) Old Apr 13th, 19, 10:13 PM
Bruce
Your '67 Chevelle should retain the '67 Upper Control Arms with the '69 12 Bolt.
Test fit he '67 uppers on the 12 bolt prior to doing any hacking on them.
I would invest in a nice set of aftermarket uppers before I'd pay to have them boxed.
Our You Tube Vids:
post #5 of 10 (permalink) Old Apr 14th, 19, 9:06 AM Thread Starter
So safe to say I can sand install bushings and paint the lowers, for the uppers is UMI safe choice? rest of suspension has been changed Bilsteins factory springs all body bushings and front bushings as well, also as the lowers are boxed would a rear sway bar help, have 1.25 Seay bar in front
Bradco is offline
post #6 of 10 (permalink) Old Apr 14th, 19, 11:01 AM
Glenn
1964 through 1967 used a longer upper control arm Bushing Hole Spacing Rear Control Arms Center to center bushing hole dimension for 1968 thru 1972 rear upper control arms is 10 1/4 inches.
Center to center bushing hole dimension for 1964 thru 1967 rear upper control arms is 12 3/4 inches.
https://www.lever-family-racing.com/...hole-dimension
Box Rear Upper Control Arms
https://www.lever-family-racing.com/...ox-rear-uppers
GM DOES NOT RECOMMEND the upper arms to be boxed. I only do it becuase people insist on paying me to do it.
12 Bolt.
https://www.lever-family-racing.com/...olt-difference
Create 12 Bolt Control Arms
https://www.lever-family-racing.com/...e-12-bolt-arms
NickeyChevelle likes this.
Glenn R. Lever
Rochester, New York 14617-2012
My Cars
Control arm Info
SS70ElCaminoOwner is offline
post #7 of 10 (permalink) Old Apr 14th, 19, 2:00 PM
Bruce
The factory Rear Upper Control Arms should be fine unless you're doing some serious road racing and have gobs of horsepower.
A rear Sway Bar would be a great addition.
I like UMI, but the choice is yours.
Our You Tube Vids:
post #8 of 10 (permalink) Old Apr 15th, 19, 10:33 AM
1964-1967 arms are 12-15/16 on center.
1968-1972 arms are 10-1/4 on center.
The arms match the year of car.
Our upper arm, axle side, are clearanced and fit both 10 and 12 bolt. The material is thick enough to not require the reinforcement patch.
As Glen mentions, a little bit of flex up there helps. Our arms are pretty stout so if flex concerns you (i.e. you want some) you can use a Roto-Joint upper. The poly ones work great for general street and performance use.
Thanks guys for mentioning UMI.
ramey
UMI Technical Support
814-376-6000
UMI Tech is offline
post #9 of 10 (permalink) Old Apr 16th, 19, 10:47 AM
Glenn
My advice to you is use Moog rubber bushing, stock arms, box the lower arms and add a sway bar. I twill not handle like the same car.
Glenn R. Lever
My Cars
Control arm Info
post #10 of 10 (permalink) Old Apr 16th, 19, 1:06 PM
Wow! A lot of good information here.
68elky396 is offline
1969 chevelle Rear trailing arms triple black69 Brakes, Suspension & Steering 8 Apr 21st, 19 2:32 PM
hpm boxed rear control arms sled Brakes, Suspension & Steering 3 Mar 15th, 16 1:07 AM
70 chevelle rear control arms not going on. Help? speed150mph Brakes, Suspension & Steering 16 Jul 14th, 15 10:17 PM
Can you remove rear upper control arms from built car easily? Bikebro Brakes, Suspension & Steering 7 Jun 15th, 14 9:54 PM
BMR rear upper control arms Fast&low Brakes, Suspension & Steering 2 Jun 2nd, 13 5:50 AM
