'67 Back end rake advice? - Chevelle Tech
  • 1 Post By dream66
post #1 of 7 (permalink) Old Apr 8th, 19, 5:09 PM Thread Starter
Looking to raise up the back end of a 67 CHEVelle. Bought 14 inch standard Eaton springs to replace a 12 inch variable pair that came w car. The car actually lowered by 1 inch ? ! Any feedback would be great on Wer to purchase/ what to buy. EATON had set of 15’s but not variable. The 14’s decreased me by an inch. So the 15’s would put me right back to the original height. Thanks for any feedback Don.
Dbjjr5428 is offline
post #2 of 7 (permalink) Old Apr 8th, 19, 5:34 PM
Bruce
Re: Back end rake
As I recall adding 1 inch to a spring (via an increase in length or a pair of spacers) will only add 1/2 inch to the lift. Summit Racing sells Coil Spring Spacers of various heights. If I'm correct you'll want a 2 inch spacer for the rear coils... Oh, and you'll want METAL spacers, not rubber.
https://www.summitracing.com/search/...rder=Ascending
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 7 (permalink) Old Apr 8th, 19, 9:02 PM
Daron
Re: '67 Back end rake advice?
I put Gabriel high jacker shocks on my 67. I only run about 35 pounds in them so my ride quality is still pretty good.Click image for larger version
1967 Chevelle SS
427 BBC
Straub Hydraulic Roller
Muncie 4 Speed
Daron Craig is offline
post #4 of 7 (permalink) Old Apr 8th, 19, 9:06 PM
Daron
Better side shot Click image for larger version
1967 Chevelle SS
427 BBC
Muncie 4 Speed
post #5 of 7 (permalink) Old Apr 8th, 19, 9:31 PM Thread Starter
With the high end jacker shocks are u still using any rear springs ? My current set up has 12 inch variable springs accompanied w air shocks. When shocks are inflated to 100 psi it barely brings frame up to level. Also at this point the vehicle is only being supported by the shocks. The springs are basically just floating in there.
post #6 of 7 (permalink) Old Apr 8th, 19, 11:39 PM
Banned
Cory
Re: Back end rake
Not on the rear which is 1 to 1 ratio. The front is 1/2 to 1 Ratio.
NickeyChevelle likes this.
dream66 is offline
post #7 of 7 (permalink) Old Apr 8th, 19, 11:52 PM
Daron
I still have the coils in. Also have a 1” spacer under them. Did you get the right length shocks?
1967 Chevelle SS
427 BBC
Muncie 4 Speed
This Thread is more than 452 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Nuclear re-construction...going back together! 540Hotrod Performance 40 Jan 8th, 18 9:37 AM
Does an engine really back pressure?? ToocoolZ28 Performance 16 Dec 9th, 17 12:35 PM
Rear end suspension set up, am I way off? CW2389 Transmission & Driveline 0 Jun 15th, 17 9:36 PM
Finally back to the track New best.Need advice rats4ever Performance 17 Mar 14th, 14 10:11 AM
Front end rebuild advice za68 1999 -- 5 Jul 23rd, 99 3:15 PM
