Lifting Rear of 1966 El Camino - Page 2 - Chevelle Tech
 24Likes
post #16 of 24 (permalink) Old Mar 7th, 19, 1:49 PM Thread Starter
Patrick
Re: Lifting Rear of 1966 El Camino
Thanks DR; that is very helpful information! What is the backspacing on the rear wheels? Iím surprised you got 16 X 7s to fit in the front. Whatís the backspacing up front? Nice wagon, btw! Thanks. P
Patrick
1966 El Camino Red/Red 327 PG
Dlr Inst A/C
Westieterrier is offline
post #17 of 24 (permalink) Old Mar 7th, 19, 3:59 PM
Kevin
Send a message via Yahoo to dirtrocker
They are 16x7 4bs up front with 225/55r16 and 16x8 5bs in rear with 255/50r-16.
1971 chevelle SS conv. dark rosewood metallic w/ black top/stripes/int. 402/4sp bench. Under resto.
1965 Chevelle Malibu 4dr Wagon, 283, pg, ps, air.
1984 Buick GN
1973 TA
dirtrocker is offline
post #18 of 24 (permalink) Old Mar 7th, 19, 6:04 PM
Clint
Originally Posted by Westieterrier View Post
Hey RAMBO, after some random searching I ran across a post of yours and a picture of a Gold Ď69 Elky you had (or worked on) in 2006. It had 15 X 10 Chevy Rallys with 5-inch backspace and 60-series tires. It looked awesome and pretty much the stance I seek. The Ď68 - Ď69 were heftier vehicles, so I donít know if I could replicate this on my Ď66. What do you think buddy? Details, sizes, and specs greatly appreciated (and earn you a few beers at my local establishment in Manhattan if you ever find yourself in Gotham). Thanks man! Patrick
15x10's with 5.0" backspacing (-12 offset) will put the rear tires into the outer fenders, unless you jack up the ride height to clear them.
Buy the correct wheels and do it right.
Clint44 is offline
post #19 of 24 (permalink) Old Mar 8th, 19, 8:30 AM
Durand
Just a couple of points.
First off, all the recommendations from/for 68' and newer don't apply to 64'-67's.(The wheel wells are vastly different for wheel/tire fitment.)
What rear axle length do you have? ( early axles are shorter ) Makes a difference on backspace.
With the early cars you are limited to a 255mm wide tire and a 8" rim max without mini tubs and some frame carving.
If your willing to modify the wheel wells and frame you can fit a 295/65-15 just barely.
Westieterrier likes this.
LaVelle is offline
post #20 of 24 (permalink) Old Mar 11th, 19, 2:50 AM Thread Starter
Patrick
Thanks LaVelle, I really appreciate this information. I suspected as such. So I have decided to go with 15X8 steel Rallys, 4.5 inch backspace and 255/60s tires on the back; Iíll leave the 14X6s up front. Thanks everyone for your considered comments.
Patrick
Dlr Inst A/C
post #21 of 24 (permalink) Old Mar 11th, 19, 11:35 AM
Clint
64-65's have tighter wheelwells and are a different animal. 66-67's have much bigger wells, not quite as large as the 68-72's, but can still handle pretty big rolling stock. 66-67 rear end are 1" shorter, than a 68-72 rear, but the backspacing requirements are pretty much interchangeable. There are a number of members here, with 64-65's, that are squeezing a 9"-9.5" width wheel and 275 tire on the rear. Lots of 66-67 owners are fitting a 10" wheel and 295 tire. The 68-72's can handle up to an 11" wheel and 315 tire, if you do your homework.
Clint44 is offline
post #22 of 24 (permalink) Old Mar 11th, 19, 3:26 PM Thread Starter
Patrick
Thanks Clint!
Clint44 likes this.
Patrick
Dlr Inst A/C
post #23 of 24 (permalink) Old Mar 12th, 19, 11:10 PM
For my 65 ElCamino, I had to go to 15x8 Wheel Vintique rallys with a 5" backset to clear the fender lip with Mickey Thompson Sportsman 255/60's. That puts the lower shock mount very close to the wheel flange, but a slight trimming clears them easy. 4 door Station Wagon springs will raise it a couple of inches and give a harsher ride.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #24 of 24 (permalink) Old Mar 12th, 19, 11:16 PM
Clint
Just for info but this is a common occurrence with 15" wheels. 17" or larger diameter wheels clear the lower shock mounts and can allow a wider wheel to be centered, in the wheelwell.
OLDED and Westieterrier like this.
Clint44 is offline
1980 El Camino - Front to rear brake line failure michael j Brakes, Suspension & Steering 3 Aug 19th, 18 6:46 PM
Rear Speaker Wall 65 El Camino Schwany El Caminos 16 Mar 20th, 18 4:12 PM
Rear end, Track Width 69 el Camino.. hydro462 Transmission & Driveline 3 Dec 6th, 17 10:32 AM
66 El Camino Rear Floor Pan 66 chevelle 496BBC El Caminos 9 Feb 7th, 13 6:24 PM
1966 Chevelle rear antenna location Foof Restoration Corner 8 Sep 27th, 12 12:13 PM
