Dash parking brake indicator - Page 2 - Chevelle Tech
 5Likes
post #16 of 30 (permalink) Old Feb 13th, 19, 4:37 PM Thread Starter
Bleeding didn’t help
Any ideas ?
Reelysalty is online now
post #17 of 30 (permalink) Old Feb 13th, 19, 5:26 PM
Mark
Re: Dash parking brake indicator
Try to bleed with at least one in front and one in rear open at the same time. Gravity bleed will work fine for this. Do this diagonally. First open the right rear and the left front and let open for ten minutes or so making sure to watch the master cylinder level as to not deplete the fluid.Then repeat with the opposite two wheels. Post back with your results.
modern malibu is offline
post #18 of 30 (permalink) Old Feb 13th, 19, 8:54 PM Thread Starter
Thanks, will try and post back
post #19 of 30 (permalink) Old Feb 14th, 19, 10:35 AM Thread Starter
Someone said there should be a rubber booted push button to re-center rod ? I have no such button that I can find
post #20 of 30 (permalink) Old Feb 14th, 19, 3:43 PM
When you bled them, did you get good pressure/flow from both rears?
Pioneer4x4 is offline
post #21 of 30 (permalink) Old Feb 14th, 19, 8:14 PM Thread Starter
I used a vacuum pump.
post #22 of 30 (permalink) Old Feb 15th, 19, 4:51 PM Thread Starter
Borrowed a neighbor, did traditional bleed starting w/furthest away.
Didn’t help.
New problem, when left tire cut hard right brake hose is the limiting factor ! Stretched to max. Does steering have bump stops or is hose too short ?
post #23 of 30 (permalink) Old Feb 15th, 19, 4:56 PM Thread Starter
Didn’t help.
There was no flow from FL when cut hard rt ! When I hit brakes hard on gravel dr (10 MPH) both front skid about 2’, nothing from back.
post #24 of 30 (permalink) Old Feb 20th, 19, 8:30 PM Thread Starter
Still chasing this.
Is valve on frame also called delay valve ?
Any more ideas ?
post #25 of 30 (permalink) Old Feb 20th, 19, 8:40 PM
On a '69, the frame rail mounted unit is just a distribution block. There should be a delay valve mounted just below the master cylinder that allows the rear drum brakes time to engage before the front discs.
jim
Jim's69Ragtop is online now
post #26 of 30 (permalink) Old Feb 21st, 19, 8:20 PM Thread Starter
There is a wire on it if I disconnect,
light goes away
post #27 of 30 (permalink) Old Feb 21st, 19, 9:55 PM Thread Starter
Here’s top side
post #28 of 30 (permalink) Old Feb 22nd, 19, 1:18 PM
You've got the correct top side parts - i.e. the delay valve. Sounds like you've tried all of the bleeding suggestions - maybe the switch in the distribution block is bad or hanging-up. I would be inclined to remove it from car and try cleaning it out with brake cleaner. That would also give you the opportunity to bench test it. With it disconnected, out of the car, the switch should center itself and be an open circuit. You can test this by putting a test light or continuity test on the wire connector and the other end on the distribution block itself. There shouldn't be any continuity with this test.
jim
Dean likes this.
post #29 of 30 (permalink) Old Feb 22nd, 19, 5:59 PM Thread Starter
Thanks, Jim
post #30 of 30 (permalink) Old Feb 24th, 19, 9:07 PM Thread Starter
A professional came by and bled brakes. Light was out for a mile or two, now it glows all the time even when brakes are not engaged.
This Thread is more than 367 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
66 Chevelle parking brake cluster Johnny Hansome Brakes, Suspension & Steering 1 Jun 22nd, 17 7:04 AM
Sweep dash indicator lights...What's the secret MidLife72 Interiors 20 Mar 8th, 16 10:01 PM
85 cadillac rear disc parking brake BSONGER Brakes, Suspension & Steering 3 Nov 26th, 14 11:01 PM
No such thing as an Emergency Brake Brian Hoss Bench Racing 45 Aug 27th, 14 12:53 AM
Brake dash light comes on with dash illumination lights? Va72Chevelle Electrical & Wiring 2 Oct 24th, 12 11:49 AM
