Front/Rear Suspension Rebuild - Page 3 - Chevelle Tech
 22Likes
post #31 of 37 (permalink) Old Mar 4th, 19, 10:16 AM
Verle
Re: Front/Rear Suspension Rebuild
Matt,
New aftermarket springs are often too stiff and raise the car. You need to compare to the old springs unless they have been cut.
I suggest you replace all brake lines, hard and soft. Safety issues.
Also replace the whole fuel line while you are at it.
The differential bushings are a "pain" to replace but you can do it. Drill the rubber in a few places and drive them out. I watched a guy use a torch to burn the rubber out. Maybe someone here will provide a procedure.
The front lower shock mounts should have captive (welded) nuts on the upper side of the control arm. Are they there? Are the threads there in good shape and the right size. The bolts go in from the bottom and there is no need for holding anything on top. If the nuts are not there/good take them off and weld the proper nuts in place.
While the suspension is off check the frame for cracks.
It may be a good idea to have the frame checked to make sure it is straight and level. It needs to be a rolling frame at the least.
Verle
Tulsa, Ok
Verle is offline
post #32 of 37 (permalink) Old Mar 4th, 19, 2:36 PM
The differential bushings are a breeze with this tool (part number 0599). Well worth the price ($89 + shipping). You will have the old bushings out and the new ones pressed back in in less than 20 minutes. One of the best tool purchases I have made. The website does not link directly to the tool (something weird about that website). When you click on the link, then click on products, then click on Bushing Tool in the blue section to see what it looks like (I will include a picture of mine, too). If you want to order it, you will have to call them.
https://www.hrpartsandstuff.com/
ID:	588056   Click image for larger version
My Chevelle w/ open headers:
WakkoWarner is offline
post #33 of 37 (permalink) Old Mar 6th, 19, 8:25 PM Thread Starter
Matt
Thanks for the replies and information!
Verle - I bought stock springs. They look to be the same height/length as the ones I pulled out, which I feel are the original ones. I hope they improve the ride and raise the front a little. I have no idea how old the shocks are, but they look really old, so I hope new ones will help with the height/ride also.
We think alike with the brake and fuel lines. I figure that I might as well take care of them now while they are easy to get at.
Question - I found two fuel lines; one down the passenger side that runs to the fuel pump, and one down the driver side the is not connected to anything. It currently stops on the frame just before the firewall. It's wide open, not capped. Any idea what the driver side fuel line is for, and is it needed?
I found new mounting hardware for the front shocks at GroundUp SS396 for about $7. It's on its way here as I type.
The frame looks good, I have thoroughly looked it over. No cracks or signs of damage. I am hoping it's straight and true.
Wakko Warner - Thanks for the info/link for the tool! I ordered it yesterday. It looks like it's going to make it a lot easier when replacing the bushings! Any other suggestions?
Thanks again for the info/help. I'll keep updating my progress.
v/r,
Matt
"New, Novice Chevelle Mechanic"
mattimuss is offline
post #34 of 37 (permalink) Old Mar 6th, 19, 8:36 PM
The other 'fuel' line may be for the charcoal recovery canister.
post #35 of 37 (permalink) Old Mar 7th, 19, 8:23 AM Thread Starter
Matt
Hey WW,
That's what I was thinking also. The charcoal recovery canister is gone so I should be able to remove the line and cap off the end at the tank?
v/r,
Matt
post #36 of 37 (permalink) Old Apr 3rd, 19, 1:52 PM
Mark
Following this with interest. Just bought a '67 SS with some 'handling' issues I'll want to address. And I'm in San Diego as well... (E.County)
MFortie is offline
post #37 of 37 (permalink) Old Jun 16th, 19, 1:44 PM Thread Starter
Matt
Hello All!
First - MFortie, I am sorry to not reply to your message sooner. Work and family have been taking up all of my time. Please PM me as I would sure like to meet!
Second - I was finally able to get the car back together this past week! What a learning experience! There was lots of sweat, more cussing and some blood involved, but she's back together and on the road again!
Thanks to all for your help/info/opinions, every single response assisted with the work performed.
I took it to the alignment shop first thing Friday morning. A.J., another big help with the rebuild, looked everything over and only found one mistake. I forgot to put the cotter pin in the driver's side upper spindle nut. Other than that, everything was put together properly.
I have taken her for a couple short [less than 20 miles] test drives and the difference is night and day! None of the tires are rubbing anymore, the differential doesn't 'twist' under acceleration, the steering is firm and responsive. It rides nice, tracks straight and doesn't pull in either direction. To say that I am pleased would be an understatement!
Again, thanks to all for all the help! I am sure that I will have more questions in the future. Who knows, maybe one day I will be able to help someone!
v/r,
Matt
Name:	Completed 06-14-19 .jpg
Kirk's67SS and lucifershammer like this.
