Rotor center hole diameter? - Chevelle Tech
post #1 of 4 (permalink) Old Jan 15th, 19, 8:26 PM Thread Starter
Hi, I'm installing a Right Stuff Detailing disc brake conversion on on my '69 with a new to me 12 bolt rear.
I installed Summit Racing replacement axles. https://www.summitracing.com/parts/SUM-700120
Now I find that the center hole in the disc brake rotor is too small for the raised section on the axle flange.
My question is: When I get the rotor machined to fit, how much larger than the axle should the hole be?
Is it this raised part of the axle that holds the rotor centered or is it the lug nut studs that hold the rotor centered?
Thanks.
danbo is offline
post #2 of 4 (permalink) Old Jan 16th, 19, 9:45 AM
Re: Rotor center hole diameter?
The axle hub diameter you have is probably 2.80" and the rotor is 2.78" which is why they don't fit. I know Wilwood solves this problem by incorporating center registration adapters for their rotors. I believe my last rear disc kit came with 3.06" O.D. adapters for a 2.804" center registration (Rotors have a 3.06" center hole diameter). See index #18 in the photo.
USAF Retired (1968-1988)
David Bates is offline
post #3 of 4 (permalink) Old Jan 16th, 19, 6:36 PM
Andrew
Thanks.
The hole in the rotor should be a snug fit over the axle. The axle register is what keeps the rotor aligned with the axles. The studs just hold the wheels on. So you're looking for a snug slip fit between the rotors and axle resisters.
Andrew
Instagram @projectgattago
Please get in touch for Holley EFI tuning services.
andrewb70 is offline
post #4 of 4 (permalink) Old Jan 16th, 19, 7:45 PM Thread Starter
Thank you both!
danbo is offline
This Thread is more than 499 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
