Disc Brake Conversion basics - Page 3 - Chevelle Tech
 2Likes
post #31 of 75 (permalink) Old Jan 17th, 09, 11:36 AM
Re: Disc Brake Conversion basics
Another upgrade would be disc brake pads for a 1990's G series van with 5 lug wheels........apparently, the mtg dimensions are identical to our D52 pads but the swept area is significantly larger. The parts number escapes me
Globe is offline
post #32 of 75 (permalink) Old Jan 17th, 09, 11:38 AM
Originally Posted by 70300deluxe View Post
how about a 78 pontiac catalina( basically 78 impala?)
Identical to the 1978-94 Impala/Caprice under the guidelines listed above
Globe is offline
post #33 of 75 (permalink) Old May 12th, 09, 5:24 AM
Robert
Originally Posted by turbopowered68 View Post
Can some one explain what ďbump steerĒ is?
But please explain it like you are talking to a 4 year old.
OR if you have a link please post it up.
better late than never, but 'bumpsteer' is what happens when you hit a bump with one(or both) wheels and your car decides it wants to steer itself in a direction other than what you intended.
threesixoh is offline
post #34 of 75 (permalink) Old May 30th, 09, 12:52 PM
bumpsteer happens when the lower A-arm and the tie rod are not the same length and/or have different mounting height at the inner and outer rim. As the suspension moves up and down the two parts move in different arcs causing steering weirdness.
post #35 of 75 (permalink) Old Jul 22nd, 09, 8:55 AM
Yanni
Hi everyone I am new hear. Glad to meet you guys. I have a 1972 CHEVELLE MALIBUE.I have a ? if anyone can answer. I have a 1996 chevey blazer with a blown motor. Before i junk I would like to know if i can put the disc brakes on my chevelle. I just dont have the money yet to get the 13"wildwood kit. The drums are really bad on the car. Have a great morning. Thank you
Yanni is offline
post #36 of 75 (permalink) Old Aug 31st, 09, 10:39 PM
Paul
I have a 70 chevelle and wanted to put a set of front disk of an mid 80's caprice. I was told that they will interchange with the monte of that gen and that they are 13" rotors insted of 11" so will they work in my Chevelle?
Paul
MyCapriceSS is offline
post #37 of 75 (permalink) Old Oct 29th, 09, 3:15 PM
Eddie
Hello all, and I apologize for this dumb question in advance. I have a 72 Chevelle with drums and I am wondering what other make/model would swap out for disc brakes. There are many cheap junk yards around my area. From what I have been reading here it seems a 72 Monte front spindle/rotor would swap over. What about the rear? Would I have to swap out the whole axle to get disc's in the rear? If so what make/model/yr? Or is there no such thing as a ez swap for rear disc brakes?
thx for you time and consideration......any replies would help.
Eddie B
Eddie B is offline
post #38 of 75 (permalink) Old Dec 19th, 09, 8:59 AM
sean
i have 98 - 02 camaro rear disc brakes on my 12 bolt was an easy swap, there is alot of info out there on this . its a nice cheap 12" rotor set up with e-brake and if something brakes or wears out you can go down to local parts house an pick up parts. i got the hole rear for 150.00 with all the parts, i had to get new pads-rotors an e-brake shoes. hope this helps good luck.
sean
http://www.poltergeist.us/page/Elky/.../ls1brakes.htm this is a great page has everything you need
chevellenut71 is offline
post #39 of 75 (permalink) Old Dec 19th, 09, 9:09 AM
Michael
Just had MBM kit installed. Getting the rear end put back in today with new shocks and springs. Did the whole front suspension. The new springs raised the car at least 2-3 inches in the front. Will advise on the braking after I test drive it.
sunbakd1 is offline
post #40 of 75 (permalink) Old Dec 24th, 09, 2:53 PM
sean
Sean,
Could you send me a link or two on how you did this swap?
Thanks, Bill
Bilster is offline
post #41 of 75 (permalink) Old Dec 29th, 09, 8:37 AM
do a search here on F body LS1 brakes and you will find everything you need. The only hitch is with the e-brake levers for axles 67 and older, but even that has several solutions (also documented here). The newer axles are a complete bolt up solution.
MJRIBEIRO is offline
post #42 of 75 (permalink) Old Jan 11th, 10, 11:51 PM
I would like to find out more about how to modify the front drum spindles to take the corvette brakes,or even the stock disc.
67mino is offline
post #43 of 75 (permalink) Old Jan 15th, 10, 12:22 AM
Eliot
now you say that using the second gen camaro spindles requries the use of either the aftermarket control arm or you said that I could use an offset control arm shaft? I didn't see the shaft anywhere on gloal wests webstite. Two if I were just to bolt them up would the negative camber be really bad or just a little bit more than usual.
70caminoman is offline
post #44 of 75 (permalink) Old Mar 13th, 10, 2:44 PM
Pip
Derek-What a brilliant article! I have 2 questions - When I strip the donor car do I take the booster/mastercylinder and metering block as well as the rear disc set up. 2nd would tubular arms relieve clearence on a big block with headers. thanks
Bustd Knuckles is offline
post #45 of 75 (permalink) Old Jul 8th, 10, 10:48 PM
Hello,
Quick question.
Are front brakes from a 78 Camaro considered "tall" spindles? If so and I use them I can use off set shafts with my factory upper arms to get the correct alignment? Since the spindle is taller will the ball joint angle be off?
Thanks!
68lemansconv is offline
This Thread is more than 1255 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Front disc Brake Conversion $$$ Questions stavros7a Brakes, Suspension & Steering 10 Jul 24th, 09 12:01 PM
my disc brake conversion tips- stock A body bhawk Brakes, Suspension & Steering 10 Nov 8th, 08 12:13 PM
Can I use my Drum Spindles for a disc brake conversion? JR67 1999 -- 17 Jan 30th, 08 9:02 AM
Disc Brake Upgrades--Jury Pool Statements 2 Ike Brakes, Suspension & Steering 3 Dec 26th, 07 12:15 PM
Disc Brake Upgrades--Jury Pool Statements Ike Brakes, Suspension & Steering 7 Jul 11th, 03 5:15 PM
